finally swapped exhaust.
Old Feb 24, 2007 | 12:57 AM
italiano's Avatar
italiano
Default finally swapped exhaust.
hey yall i finally swapped out my stock exhaust.went with vance and hine bss.i noticed that now when i get on it and notice a vibration in conjunction with engine speed.i was wondering if the factory exhaust has dampers of some sort i didnt feel it so much before.btw love the sound it is awsome.and looks great.
Old Feb 24, 2007 | 02:31 AM
wldbill's Avatar
wldbill
Default RE: finally swapped exhaust.
Changed mine out to V&H Bigshot staggered and noticed nothing but more power and noise. Got a picture?? Somethings loose?
Old Feb 24, 2007 | 06:57 PM
italiano's Avatar
italiano
dont know how to do pics yet it is a little confusing.ive checked and all the bolts seem tight.i torqued the nuts at the motor to 20ftlb and the bracket nuts i muscled them down.
Old Feb 25, 2007 | 01:12 AM
flibuoy's Avatar
flibuoy
Agree with above, had them on Dyna and no vibration. If nothing obviously loose then suggest you loosen everything a bit and then starting at cylinders work back through carefully retightening. Great pipes for quality, looks, sound and overall performance. Don't forget heat shields when checking. John
Old Feb 25, 2007 | 02:30 AM
italiano's Avatar
italiano
i dont think i have a real problem.all is tight and seems ok.the vibration may be normal.it isnt bad maybe its just the motor.its only when i get on it hard.probably the vibration from the sound.just wanted to make sure i wasnt nuts thats all.
Old Feb 25, 2007 | 07:02 PM
Lunder99's Avatar
Lunder99
The pipes aren't rubbing against each other any are they? I wouldn't think they would be but might be worth checkin...
Chris
Old Feb 25, 2007 | 10:54 PM
italiano's Avatar
italiano
no they arent bss are cojoined by the power chamber.i figured one thing out.i found the bracket that attaches the pipes to the bike was mounted on by 2 studs and then 2 nuts.the studs were spacing the pipes away and wasnt seating well.i removed the 2 studs and used 2 bolts and it is alot better had to loosen the whole system to reset.
HardLuck71
Exhaust System Topics
23
Aug 14, 2017 07:41 PM
pheur
Sep 20, 2014 04:56 AM
Eagle240
Sep 27, 2012 09:54 AM
LaRider
Oct 7, 2010 05:37 AM
dmercer
Aug 19, 2008 05:34 AM
