Softail Carb Misbehaving: Help Needed
Old Jun 17, 2013 | 10:13 AM
scooper321's Avatar
scooper321
Default Softail Carb Misbehaving: Help Needed
So I have a friend who has a problem. And yes, this really IS for a friend. I ride a RK. LOL
Anyway, the bike is a rebuild from a 1998 Heritage, now mostly a FatBoy. The issue is with the carb. Basically, it sputters bad for the first 30 minutes of riding, then if she eases off the throttle and back on... chugs. Down shifting, she's getting backfires. This just started happening out of the blue on Saturday.
Any thoughts? Is there enough info here to go on, to get possible suggestions?
Thanks in advance!
Old Jun 17, 2013 | 11:47 AM
o/d's Avatar
o/d
blocked pilot jet possibly. hard to tell over the internet, but that's were i'd look 1st.
the float bowl can be removed easily with carb on the bike fwiw.
or just pull the carb off the bike & go over it. perhaps the diaphram is damaged.
Old Jun 17, 2013 | 01:33 PM
Knucky's Avatar
Knucky
Yeah if it idles rough it's probably a pilot jet issue but do all the easy troubleshooting first - make sure the tank, fuel filters and lines are clear, sparkplugs are fresh and firing, ignition coil is OK, plug wires are OK, there's no exhaust header leaks, air intake is clear, compression is good, no vacuum leaks, etc. If all that checks out, and things still aren't right, I would then typically pull the carb, clean it, and rebuild it with a kit like this one.
pacman552sd
Carburetor Related
Jun 3, 2015 10:39 PM
sglidegolf
May 13, 2011 06:56 PM
Bruno2
Mar 2, 2009 08:29 AM
piercedreality
Ironhead
Jul 9, 2008 04:59 AM
old kid
Exhaust System Topics
May 14, 2006 02:49 AM
