Could flasher be problem ?
Old Jun 20, 2013 | 12:02 AM
Flip50's Avatar
Flip50
Default Could flasher be problem ?
90 softail flstc. Lost left front blinker and running light . Been searching forum for couple of days and can't seem to pinpoint problem. I changed bulb still nothing. Wondering if flasher gives pwr to running light and blinker. I have Vom and test light but haven't had time to check it out yet . Left taillight stays on but does not flash with blinker on. Right side no problem front or back. Wondering if socket could be bad and if so will I have to buy whole light. Any help would be appreciated this is driving me crazy trying to figure it out!
Old Jun 20, 2013 | 01:23 AM
Dangermouse's Avatar
Dangermouse
If both quit at the same time it is probably the ground. When one signal quits ie front left, the remaining light, ie rear left will stay on
Old Jun 21, 2013 | 05:39 PM
Flip50's Avatar
Flip50
I did check left front running and blinker socket I do have voltage . Also put in known good bulb and still does not light. I checked wires and can't find anything broken or cut. Can the light socket be bad even though one dot on socket shows voltage?
Old Jun 21, 2013 | 05:50 PM
Jackie Paper's Avatar
Jackie Paper
I have see older bikes like yours have the round plastic disk that the two contacts are separated by crack and let the two springs get together behind it or go to ground. Usually takes out a fuse if it gets to the ground but I bet if the run and signal wires get together, it will not flash but you would think it would burn. I guess your one hot lead is run light. If that does not come on, you either still have a new bad bulb or no ground on the outer case were the pins of the light catch. Remember all bulbs are not created equal, and an auto bulb will be short lived when you do figure out what is wrong.
Old Jun 21, 2013 | 06:25 PM
Flip50's Avatar
Flip50
Yes I see two springs are together. I removed plastic disk to see if wires were broken . One filament is for running light other for blinker. So if I'm understanding correctly, one spring should be behind each dot then put back into socket right?
Old Jun 21, 2013 | 06:48 PM
Jackie Paper
It could be under the vibration and such that they receive, may want to replace or rebuild socket. So many versions, it's hard to call that over the internet. Most have the lead button on top that you see that the lead dot of the bulb contacts. Under the disk, the spring is preloaded by the wire and keeps it all tight and away from going to ground or getting into other spring. Of course the outer shell is ground for both run and signal. Is your disk plastic or is it fiber (fiber seems to hold up) But to answer you question, yes
Old Jun 21, 2013 | 07:05 PM
Flip50's Avatar
Flip50
It could be under the vibration and such that they receive, may want to replace or rebuild socket. So many versions, it's hard to call that over the internet. Most have the lead button on top that you see that the lead dot of the bulb contacts. Under the disk, the spring is preloaded by the wire and keeps it all tight and away from going to ground or getting into other spring. Of course the outer shell is ground for both run and brake. Is your disk plastic or is it fiber (fiber seems to hold up) But to answer you question, yes
Disk is plastic. This is for running light and blinker only. I will reposition springs to make sure disk is making contact with bulb. Thanks for the info..,I at least now have a starting point.
Old Jun 21, 2013 | 07:39 PM
Jackie Paper
Brain not in gear, run and signal.
Old Jun 22, 2013 | 02:39 PM
Flip50's Avatar
Flip50
Thanks ripsaw. The plastic disk had turned and not making contact with bulb. I now have running light but still no left blinker. Was going to try new blinker relay but can't figure out how to get odometer **** off on my 90 softail! Not even sure if blinker relay is under there but was going to check and replace relay to see if I get a left blinker . At least making some progress anyway.
Old Jun 22, 2013 | 02:58 PM
Jackie Paper
Think the blinker TSM (mine is the TSSM since it is also alarm) is driven off 3 15 amp fuses, the ignition, accessories and battery all supplied by the main circuit breaker. Mine also has a 3 amp additional fuse and start relay driving it. The main and TSM are behind the plastic cover in front of my rear wheel. Mine also has a 3 amp additional fuse and start relay driving it. The main and TSM are behind the plastic cover in front of my rear wheel. The big white plug is the signal, the breaker is above it. When you throw your signal light on, I assume you are not getting power to the other terminal yet rear come on and does not flash? If that is true, I still think the problem is with the bulb socket. The TMS will do strange things when any bulb resistance is not correct to show you have a problem.
