Breakout front brake ????
Old Jun 24, 2013 | 11:48 AM
jjgi5150's Avatar
jjgi5150
Default Breakout front brake ????
Hi all,
Just rode the Breakout today after it had to sit for about 5 days. It is running great...got the fuel map set at a perfect spot (many thanks to Jaime at Fuelmoto...and PowerVision)! However, I did notice a small issue when backing it out of the garage to ride.
My front brake felt pretty spongy as I was rolling it down the driveway. The lever had to be pumped about 4-5 times to get it to where it normally sits/feels. There are no visible leaks anywhere on the brake line or caliper, and not low on fluid. After pumping the lever, all was back to normal and the front brake worked perfectly for the rest of a 40 mile ride this morning.
Has anyone else experienced this on a newer Harley? I only have 505 miles on the bike now.
JJ
Old Jun 24, 2013 | 01:34 PM
Hogpro's Avatar
Hogpro
Former Sponsor
Take it back to the dealer for warranty. Probably needs to be bled again.
Old Jun 24, 2013 | 01:40 PM
jjgi5150's Avatar
jjgi5150
Hi Hogpro,
Yeah, that is what I will do. I just checked it again after is sat for a while from my ride this morning. There was a little less feel when I tried the brake lever. After the first pump, it was ok again. This time I felt under the MC banjo bolts, and there was a very, very slight slick, slimy brake fluid feel on the underside of the washers on the banjo bolt. I did not notice this before. It may just need new washers, or to be properly torqued down.
JJ
skos
Mar 28, 2020 09:58 PM
zgunnar48
Apr 30, 2015 07:08 PM
WVHogRider
Mar 27, 2012 08:05 AM
Scooter68
Jul 24, 2009 08:26 AM
GBeck
Screamin Eagle CVO Models
Jun 30, 2009 10:54 AM
