shock adjustment jam nuts
Old Jul 3, 2013 | 02:36 PM
olskoolblu's Avatar
olskoolblu
Default shock adjustment jam nuts
I just adjusted my shocks, everything went fine until I tried to tighten the jam nuts. I couldn't fit the both the 9/16 and the 1 1/16 wrench in there to get it good and tight. I just tightened the jam nut down best I could. Anyone ever have problems with them loosening? Thanks in advance.
Old Jul 3, 2013 | 06:19 PM
Bluraven's Avatar
Bluraven
Your question made me check my own shocks since I adjusted them a month or so ago and didn't even know that the threaded shaft had a 9/16 fixed nut.
I only tightened down the jam nut using my shock adjustment tool.
I'll be damn, one of the jam nuts was backed out but the shock Can doesn't appear to have moved (I have both Cans marked).
I was able to get a 9/16 wrench on the threaded shaft and my shock adjustment tool on the jam nut to tighten it down.
I have my shocks adjusted as far out as I can with the shock adjustment tool while still being able to tighten the jam nut with the tool.
This leaves plenty of room to get a regular 9/16 and 1 1/16 wrenches on.
With about 400 .lbs on the bike I never bottom out so you either have more than 400 .lbs on the bike or you have the shock cans adjusted for way more than 400 .lbs.
So I think perhaps you either need to back the cans out a bit or go ahead and tighten only the jam nut.
So to answer your question; yes without holding down the 9/16 threaded shaft the jam nut can loosen itself.
Old Jul 3, 2013 | 06:35 PM
olskoolblu's Avatar
olskoolblu
lol. Ya, I was adjustin for a bit over 400. I'm an easy 260 and my GF occasionally rides with me with luggage. Depending on the ride, I may back off a lil. Thanks for th reply, I'll keep an eye on them.
Old Jul 4, 2013 | 08:13 AM
wiktor's Avatar
wiktor
I use the HD spanner to hold the can in place and then use a wrench to tighten the nut. I know what you're saying, with the shocks adjusted there is no room for two wrenches.
sel53
Dec 16, 2013 08:08 AM
checkers
Jun 30, 2013 06:39 PM
Bloozmann
Apr 21, 2013 10:45 AM
prstaples1911
Apr 13, 2013 10:38 PM
Paulmy
Jul 24, 2012 12:55 PM
