Breakout Riser Extension?
Old Jul 11, 2013 | 07:38 PM
fldime's Avatar
fldime
Default 1" spacers added
Added the 1" spacers today. 11/2" will fit without a problem.
Old Jul 11, 2013 | 10:29 PM
Chaparro78's Avatar
Chaparro78
My 1.5" spacers arrived today. Bike getting serviced so could not install. Will mock up and take more pics once they are on, then sending them out to get powder coated sunglo red
Old Jul 11, 2013 | 11:01 PM
parttime379's Avatar
parttime379
did the spacers add enough height to keep the throttle cables off the tank?
Old Jul 12, 2013 | 05:15 AM
fldime's Avatar
fldime
Parttime379, they still lay on the tank, maybe not as hard against the tank.
Old Jul 12, 2013 | 07:02 AM
crawlgsx's Avatar
crawlgsx
Awesome thanks, keep us posted! If they fit no problem with the stock wires I am going to order a set of 1.5" as well and send them to be chromed
Old Jul 15, 2013 | 03:40 PM
jskicet's Avatar
jskicet
Default Spacers
How does it feel? Can you tell the difference in the reach? I'm interested in these if it helps.
Old Jul 18, 2013 | 05:19 PM
Chaparro78's Avatar
Chaparro78
Default 1.5" Spacers Installed
Here are some pics of the 1.5" spacers I installed that SpacerJim made.
I am 5'7" / 165lbs and the 1.5 inches that it brought the bar closer to me made a big difference. Definitely cannot go bigger without new cables. The break line loses its slack when turned all the way left but not tight. I ride more upright and because I am a little back more it's easier to plant my feet on the ground.
Attached Thumbnails Breakout Riser Extension?-dsc00080.jpg   Breakout Riser Extension?-dsc00084.jpg   Breakout Riser Extension?-dsc00085.jpg   Breakout Riser Extension?-dsc00086.jpg   Breakout Riser Extension?-dsc00088.jpg
Old Jul 19, 2013 | 08:51 AM
crawlgsx's Avatar
crawlgsx
Awesome thanks Chap!
That looks great! I will definitely be getting a set, thanks for being the guinea pig :-D.
I ordered some and sent them to Nuchrome in MA who apparently "lost" them. *sigh*.
Will have to order another set and try to find someone more reliable to chrome them.
Old Jan 14, 2014 | 09:53 AM
jweinsteiger's Avatar
jweinsteiger
Default Same Question
I was wondering the same if the 1" spacer keeps the cables off the tank also is anyone using Polyurethane Handlebar Riser Bushings when the do this mod?
Old Jul 13, 2015 | 04:00 AM
ulev1st's Avatar
ulev1st
So I like what I see with the 1 1/2 Alum spacers from "Spacer Jim".
I followed the link in the thread to spacerjim.com and I don't see any thing about motorcycles.
Does anyone know if he is still in business... updated contact info? Thanks
