Oil filter change
Old Jul 8, 2013 | 06:04 AM
Hair53's Avatar
Hair53
Default Oil filter change
Any tricks for keeping the majority of the oil off the engine when changing the oil filter?
Old Jul 8, 2013 | 06:09 AM
QC's Avatar
QC
Some have used a soda bottle with the bottom cut off. Poke a hole in the top of the filter where the side meets the end and loosen the filter. When the hole reaches the bottom it will drain into the soda bottle. I have not done this myself. I just wipe with the "show" towels and spray it down with brake cleaner.
Old Jul 8, 2013 | 08:14 AM
tbonetony06's Avatar
tbonetony06
Harley sells this oil thing that fits under the filter for the oil to flow to a pan. Poke a hole in the end and let it drain on oil thing, break filter lose so it can get air and better drain after you have poked the hole in it. It's been the cleanest and easiest way I have ever done it.
Old Jul 8, 2013 | 08:17 AM
NDBadlands4-2's Avatar
NDBadlands4-2
I bought the oil change thing that Harley sells. It kind of works, but you still make a mess. I do not use it now. Just be as clean as I can and clean up afterword.
Old Jul 8, 2013 | 08:35 AM
hyde802's Avatar
hyde802
I tried the soda bottle trick. Sort of work, but I still end up cleaning up. So now I just make a mess and wipe it down after. Horrible design for an oil filter location IMO.
Old Jul 8, 2013 | 08:57 AM
SprungDave's Avatar
SprungDave
I (re)use heavy duty aluminum foil shaped to fit under the filter and guides oil into the oil pan below the bike. It still makes a mess, just less so. I have tried everything to stop the mess. It is just a lousy design.
Brake cleaner (to remove the mess), followed by pig spit is the only way to keep the engine looking nice and clean after an oil and filter change... F that (those) engineer(s) and bean counters for not designing (or agreeing to) a better solution after all of these years and thousands of gallons of cumulative spills.
Old Jul 8, 2013 | 11:03 AM
bikefxds's Avatar
bikefxds
Default cereal box
The vertical end of a cereal box works pretty well. Just cut one end of the box so you have a vertical channel sort of shaped like a vertical "U". Then cut the "U" into a "V". One side of the "V" is about one inch and the other side of the "V" is about 2". Slide the thing under the filter with the short side facing the motor all the way underneath the filter. The length of the thing just about makes it to the left floorboard where you can kind of direct the flow into an awaiting container below. A little mess as always, but it's the best thing I've tried so far. Then the obligatory brake cleaner spray to complete the job after the new filter is put on.
Hair53's Avatar
Hair53
Default Transmission clunk
My sportster had this same issue when changing gears and my heritage is doing the same thing, it doesn't do it all the time but most of the time, I have tried different rpm's but that doesn't help. Is this normal?
Old Jul 8, 2013 | 11:06 AM
Hair53's Avatar
Hair53
I intended to make this post a new thread but it didn't work out, damn iPad..lol.
Old Jul 8, 2013 | 01:29 PM
Bluraven's Avatar
Bluraven
Good time for the thread, I'm about to change my oil this week.
I was going to buy the Harley "oil thing", but after reading these comments perhaps I'll just try to trap as much as possible and put down kitty litter under the bike to catch the rouge oil, then clean up afterwards.
