Gear position indicator acting weird. Any ideas?
Old Sep 24, 2014 | 09:25 PM
Fatbob usmc EOD's Avatar
Fatbob usmc EOD
Originally Posted by checkers
15K on my Heritage and having digital tach resetting to odometer when engine is restarted. Did you ever figure out what was wrong with yours?
I just learned to ignore it after a while. It's got around 24,000 miles on it now and gets on down the road so I just stopped worry about it I guess. Might try that reboot thing though just for the heck of it. Like Sgt Jim I've also had the sixth gear light come on occasionally but can't point to anything wrong so it's just going on the ignore list too.
Old Oct 6, 2014 | 01:39 PM
checkers's Avatar
checkers
I installed new battery this week end and it solved the digital reset in window and the slow crank warm, my OEM batery was week and was 3.5 years old. just an update
Old Oct 11, 2014 | 07:56 AM
checkers's Avatar
checkers
Originally Posted by Pitbull_Dallas
It may be a software glitch in the speedo. The way that thing works is it calculates which gear your in based on speed and rpm. It's not calculating right. Saw something on another thread that might work. Kill the power to the speedo (I'd disconnect the battery cable) and let it sit for a while. Kind of a reboot. Reconnect the cable and see what happens. Won't hurt to try.
Checkers, I think at saw it of your thread. Did you try what I just said? You have to completely disconnect the negative side st the battery because there are a couple of grounds on that terminal.
Digital display resetting to odometer after restart update: Last week end I installed a new Deka Big Crank from Battery Mart. I have ridden several times with numerous cold and hot starts. Motor cranks over like it should and it does NOT reset digital display. Battery was the issue. Battery was $85 shipped with discount coupon and came in 2 days fully charged.
Steevo Jolly
Jul 24, 2018 05:58 PM
BKSinAZ
Sep 26, 2012 06:05 PM
roundy
Aug 13, 2012 06:22 AM
jada3058
Jun 4, 2011 07:06 PM
skulznflames
Exhaust System Topics
Jun 4, 2008 10:03 AM
