Stability help...
Old Jul 12, 2013 | 04:46 PM
Warp Factor's Avatar
Warp Factor
You might start by checking the adjustment of the steering head bearings. If they're off a ways, you'll probably be able feel play or clicking when the bike is on a jack, and you pull forward on the forks.
Next thing to check might be condition of the swingarm bearings.
Old Jul 12, 2013 | 05:10 PM
tbone108's Avatar
tbone108
Have you thought of trading it in for a dyna if you like the dyna ride.
Old Jul 13, 2013 | 12:05 AM
SwiftyBKells's Avatar
SwiftyBKells
Definitely not trading down to a dyna! As fas as suspension, I'm slammed with bolts, lower than almost any bolt job I've seen. Doing that only makes me feel the bumps on the road. the 21" up front is stock, full of air, & was just ballanced with a brand new tire. The front isn't lowered...yet.
Are there any aftermarket add ons to get softails to have a smoother ride at highway speeds. ill sacrifice the stiff feeling for being low but my bike shakes like a person with hypothermia at anythinjg over 65mph.
Old Jul 13, 2013 | 12:36 AM
Midgard's Avatar
Midgard
I am assuming you have checked for loose spokes front/rear.
So - 1st off - like Warp said - check your neck bearings ~
Lower the front 2" with a drop in kit from Progressive.
Also look into a 120 series tire on a 3.5 " rim up front.
*Edit - just read your latest post ^^ these will just make it feel a little more "stable"
- the shaking is something mechanical for sure (1st I thought you meant a feeling like the start of a speed wobble)
Old Jul 13, 2013 | 03:57 AM
tbone108's Avatar
tbone108
Interesting that you feel that a dyna is a lesser bike than the soft tail. IMO they are different bikes for different riders. I have been on the softy 96 inch at all speeds and it was smooth as can be, the main down side for me was the ground clearance for corners. The uk is just a network of twisties and I need to keep up with the other riders. Tyres and pressures,spokes, wheel bearings, loose bolts,head bearings. swinging arm. good luck hope you get it sorted.
Old Jul 13, 2013 | 10:14 AM
knightenforcer's Avatar
knightenforcer
You got to think about what you changed on the bike prior to having this problem.
(back track) Has the bike always done this or did it start doing this after the suspension and wheel change? This is how I would start diagnosing the prob. Just my 02 cents
Old Jul 13, 2013 | 04:35 PM
rleedeuce's Avatar
rleedeuce
Default Goodbye to Wobble
Does the shake also happen when you let off the gas at 50 mph while letting go of the bars or at least just barely holding them? If so that is a classic symptom of loose frame neck "head" bearings and you need to set the tightness to get rid of the slop.
My Deuce was delivered so loose it had a speed wobble at 45 mph!!! I could barely drive it.
As for all the comments about lowering the rear changes the trail which is BAD etc etc. Don't believe it. The change will NOT affect a speed wobble. At most it will ADD a touch more stability as you have more rake and trail than stock.
But I doubt even the princess and the pea could actually "feel" the difference.
I raked my Deuce with 3 degree bearing cups and extended the forks four inches to gain more road clearance in the corners. The stability INCREASED and the bike cornered with a more planted stance perhaps due to the increase in wheelbase. I went from 35 to 38 degrees rake and probably added a half inch to the trail. Best thing I ever did for the handling and it looks outrageous. Tons of cornering clearance now.
YOUR problem sounds like a loose bearing somewhere or loose spokes... Or a flat tire. Or worn out fork sliders or wrong amount of fork oil. Or bad REAR shocks.
Check EVERYTHING including alignment. A Harley should feel BETTER as you hit 100 mph. Not WORSE.
Old Jul 13, 2013 | 05:44 PM
Benway's Avatar
Benway
My bike is slammed to the ground with a 21" up front
Well there's your problem. You can't have your cake and eat it too. You want a Lazy-Boy recliner, you don't build a deck chair.
Old Jul 13, 2013 | 09:31 PM
Midgard's Avatar
Midgard
^^ nope. Its something mechanical - I am still thinking neck bearings
Old Jul 13, 2013 | 09:33 PM
KumaRide's Avatar
KumaRide
Unbelievable some of the comments in this thread suggesting what the problem is, or is not. Seriously - You have a 21" gyroscope up front wheel that changes your front suspension behavior and the bikes geometry/rake/trail is now messed up, the rear has no suspension travel cause its slammed incorrect sag setup and also changes the rake/trail... hell ya the dyna feels great!!
Due yourself a favor and google suspension, rake, trail, setting up sag, lowering rear... and get from bike rags and professionals before some one gets hurt.
