Throttle hands goes numb
Old Jul 13, 2013 | 04:22 PM
BTilly's Avatar
BTilly
Default Throttle hands goes numb
I ride a 2009 fatboy. After around 30 minutes my right hand goes numb. The bike has drag bars. This happen with factory bars also. There is no vibration, no other shakes etc.
Any one elae have this problem and find a solution?
Thanks
Bob
Old Jul 13, 2013 | 04:23 PM
rooti's Avatar
rooti
try loosening up your grip
Old Jul 13, 2013 | 04:30 PM
Arrogant Bastard's Avatar
Arrogant Bastard
Hold it like you would a bird. Tight enough so it won't fly away, but not tight enough to squeeze its guts through its ***.
Old Jul 13, 2013 | 05:18 PM
Misbehaven's Avatar
Misbehaven
Like others have said loosen your grip. You might find that a cramp buster may help.
http://www.crampbuster.com/
Old Jul 13, 2013 | 05:36 PM
rocknrod's Avatar
rocknrod
Yep crampbuster or one like it and a lighter grip.
Old Jul 13, 2013 | 06:07 PM
Greenhead17's Avatar
Greenhead17
I have same problem. But I'm a welder and contributed it to that. I find I squeeze the mig gun and my grinder with a death grip sometimes.
Old Jul 13, 2013 | 06:50 PM
olongapo1's Avatar
olongapo1
It's all about hand position. I've had the same problem on other bikes with different bars. I'm currently running Beach Bars on a Fatboy. My hand and arm position, and wrist angle are perfect. I can ride all day without numbness or fatigue. Sometimes you have to sacrifice Looking Cool for practicality and functionally.
Old Jul 13, 2013 | 07:12 PM
Cygnusx51's Avatar
Cygnusx51
Originally Posted by olongapo1
...sometimes you have to sacrifice looking cool for practicality and functionally.
never!!!!
Old Jul 13, 2013 | 07:14 PM
Gliden's Avatar
Gliden
Default numb hands
Agreed.
Your unknowingly doing a death grip causing lack of blood flow.
Loosen up.
Old Jul 13, 2013 | 07:16 PM
checkers's Avatar
checkers
Thanks
Bob
If you have aftermarket exhaust installed it can make it worse. Exhaust can be loosened and neutralized. Bar end weights can be installed to help. Also there is a company that sells a handlebar snake that eliminates bar buzz by 90%. You will have to do some searching to find it on the internet. If you use a throttle "paddle" that rests in the palm of your hand, it will help. Also a throttle lock lever that mounts to the stock throttle lock, will also help.
