Decimated Decibels
Old Jul 23, 2013 | 01:03 AM
cgmartine's Avatar
cgmartine
Cool Decimated Decibels
After experimenting with different mufflers and not getting the sound I was looking for, I took a suggestion from someone on the boards and inserted one wad of heavy duty steel wool inside each baffle. I made a wire mesh cap to keep the wad all inside. It all went inside up to the half way point in the baffle, where the welded divider is. Wow, I could not believe the difference, the sound level must have dropped by about 10 to 15 decibels. Finally, the soft sound I was looking for. My only concern, will this create additional heat, since the baffle already has a cat? (2006 Heritage. Staggered pipes).
Old Jul 23, 2013 | 07:12 AM
47909Rider's Avatar
47909Rider
Huh.
Have you got any more information on this? Does it have any effect on performance/etc?
I love my Rush slip-ons, but shaving 10-15 decibels would make my neighbors happier when I leave every morning at 6...
Old Jul 23, 2013 | 10:31 AM
TheTroupe's Avatar
TheTroupe
The steel wool will rush out in short order. Check out one of the forum's sponsors http://www.americancustom.com/ I am not affiliated with them and I get no compensation, but I have heard great things about their custom mods.
Old Jul 23, 2013 | 08:15 PM
cgmartine's Avatar
cgmartine
Default Home remedy. It worked.
This is not really the fine steel wool you might be envisioning...its heavy duty..its the pot scrubbing kind, kinda like a wiry type. It's not for sanding. Since the baffle has about 1 3/4 in pipe running inside its lenght, I was able to put a heavy duty wire mesh screen across the entrance, and secured it with a hose clamp. Nothing will be ingested into the engine because the pipe in the baffle has a welded section in the middle, which divides it into two chambers. Its not coming out by itself, believe me. I don't believe the steel wool will deteriorate any time soon, at least not the way the asbestos sheet covering the baffles has. I am just concerned about additional back pressure and the resultant heat created. Other than that, its good. If I feel a heat increase, I will just undo the clamp and out comes the whole thing.
Old Jul 24, 2013 | 04:38 AM
oct1949's Avatar
oct1949
That sheet Ur talking about that covered U baffle is prob made out of Fiberglass, I'd almost bet the farm its not Asbestos, Unless someone personally changed it out.
Old Jul 24, 2013 | 06:20 AM
cgmartine's Avatar
cgmartine
I couldn't come up with the word for it, but yes, it is fiberglass, and it was in bad shape, torn in places. Once I rolled it around the baffle a couple of times, it was not too bad.
Old Jul 24, 2013 | 06:24 AM
47909Rider's Avatar
47909Rider
If it was asbestos, it wouldn't suffer damage from the heat.
It would also be (I believe) illegal for sale...
Old Jul 24, 2013 | 07:45 PM
fcsallan's Avatar
fcsallan
The result is more back pressure. If you tune for it, it should be fine. The cat already is quite restrictive so I know I would not go this way, but I prefer performance to quiet.
With a coarse wool you should be fine as far as heat / fire risk, it is the finer wool that is more likely to catch fire. It would look cool as hell going down the road, but I'm sure that's not what you were looking for.
UltraDave
Dec 18, 2011 08:11 PM
TORQUEY
Feb 16, 2011 07:54 PM
'05Train
Feb 5, 2011 06:14 PM
trapper_canada
Exhaust System Topics
May 20, 2009 03:35 PM
Thirdup
Dec 22, 2007 10:53 PM
