When should battery indicator light function
Old Jul 25, 2013 | 10:31 PM
Falcon195's Avatar
Falcon195
Default When should battery indicator light function
2012 FLSTF.
If the stator or voltage regulator are not functioning properly should the battery indicator light on the speedo be lit?
For example if the battery isn't being charged when the engine is running, should the battery indicator light be lit?
Old Jul 26, 2013 | 01:14 PM
Falcon195's Avatar
Falcon195
What was this question really that stupid that nobody wants to answer.
I understand that the batt. light should be lit if there is a problem with the battery or charging system.
But after doing a search I see several posts about battery or charging problems but I don't see any indicating a battery light being on in conjunction with these issues.
So this is why I am asking the original question.
Old Jul 26, 2013 | 02:00 PM
xwhyz1959's Avatar
xwhyz1959
Common sense tells me it should be like a car. If your bikes electrical draw is larger than what your charging system is putting back into your battery, the light should come on.
Old Jul 26, 2013 | 02:51 PM
Mr.Softy's Avatar
Mr.Softy
I can say that my light never came on and the battery had a short in it. Never knew I had a problem until it wouldn't start one day.
Old Jul 26, 2013 | 09:56 PM
Aaresz's Avatar
Aaresz
My 2012 Deluxe was involved in the regulator recall last summer. Battery lamp came on alarming me of an issue before being notified of this of the recall.
Old Jul 28, 2013 | 05:07 AM
FroggyFatBoy's Avatar
FroggyFatBoy
xwhyz is correct, it will only turn on if the charging system can't keep up with demand. as long as the actual charging system is ok, the batt light won't turn on if the batt itself is weak, its not designed to.
some new cars have batt sensors that will monitor batt state, but i imagine its years off in the bike world, which is a good thing in my opinion.
to test the batt light operation, hold in the trip/reset button and turn ign on. all the dash/console lights and gauges should light or make a full sweep of their range accordingly.
Poisnd
Electrical/Lighting/Alarm
Jul 8, 2021 03:30 PM
sanman4ever
Mar 10, 2016 04:40 PM
fignuton
Oct 11, 2015 03:24 PM
2ropes
Mar 31, 2014 06:10 AM
bra$$monkey
May 6, 2011 06:55 PM
