Riser question
Old Aug 2, 2013 | 09:05 AM
Rick341's Avatar
Rick341
Default Riser question
I want to install risers on my 05 Heritage... no ape hangers, just a 4 1/2" rise and 1 or 2" set back... J&P Cycles has some listed that are made of "die cast" but I've heard that steel is far better and safer.. My question is: why? Are "die cast" risers unsafe because they are weaker than steel? Has anyone had any issue with them failing for any reason? The die cast are a lot less expensive, but if they're not safe, I'll try to find some made of steel.
TIA
Old Aug 2, 2013 | 09:50 AM
Mr.Softy's Avatar
Mr.Softy
Just my opinion but I wouldn't buy die cast risers for my bike. You can have porosity inside the casting and not be aware of it. I got the risers from HD money well spent. There are probably others available and I am not preaching HD anything. Buy Steel/chromed and you will be better off.
Old Aug 2, 2013 | 10:26 AM
rgjujitsu's Avatar
rgjujitsu
I love my new after hours chopper risers. One place you don't want to cheap out is risers.
Old Aug 2, 2013 | 12:16 PM
Rick341's Avatar
Rick341
Thanks... that's what I needed to know... Now, does HD or anyone else make 4 1/2" chromed steel risers that have the single cap like the original? I can't seem to find anything except the risers with individual caps.
Old Aug 2, 2013 | 12:31 PM
soft 02's Avatar
soft 02
All the good one's ive seen are billet aluminum in that length. Nothing wrong with billet aluminum.
Old Aug 2, 2013 | 01:04 PM
XARAN's Avatar
XARAN
I would not use cast risers, if they broke your down. I had these in 4" on my Fatboy. They come in lengths up to 9" and are made of billet aluminum
Buffalo Risers, they use the stock 1 piece top clamp
http://www.motorcycle-superstore.com...lo-Risers.aspx
Old Nov 13, 2023 | 09:47 AM
mynewhd's Avatar
mynewhd
Deleted - Wrong forum!
Old Nov 13, 2023 | 03:04 PM
House O' Payne's Avatar
House O' Payne
I've ridded at least 3 bikes with Aluminum risers for years and never worried about them being aluminum. I've been riding 45 years now and have never heard once of a fellow rider's issues with aluminum risers, or even read about it. The forces that would be needed to break your risers would likely mean you're dead, or at least in a state where a broken riser would be the least of your worries. Buy steel if it gives you peace of mind though.
RadRodriguez
Mar 22, 2018 08:10 AM
Rollcage
Jun 3, 2016 05:17 PM
sigsauer33
Apr 4, 2012 08:38 PM
SPECIAL ED
Mar 12, 2012 03:05 PM
NCTURBOS
May 12, 2011 11:11 AM
