Quick release windshield
Old Aug 26, 2013 | 08:15 PM
sbcvulcan's Avatar
sbcvulcan
Default Quick release windshield
Easy enough to install brackets using directions. Really had to push the windshield on. Paperwork says easy off by just lifting,,,, had to loosen screws. I thought this release was supposed to be tooless. This is an HD windshield on an 07 Deluxe. Called a friend of mine who had one, seems to recall it not really being as easy as the directions refer to it as.
Not going to take it on and off alot, every creak and crack as installing it was nerve wracking. How easy is this thing truly?
Old Aug 26, 2013 | 08:22 PM
FXDWG12's Avatar
FXDWG12
Mine is easy enough that I'm worried someone else may like it more than me.
Old Aug 26, 2013 | 08:47 PM
JRL1164's Avatar
JRL1164
I just pull the lock pins to the side and wiggle mine off. No tools or nothing, just gotta slide it off he rubber grommets.
Old Aug 26, 2013 | 08:56 PM
tidbit1's Avatar
tidbit1
Old Aug 26, 2013 | 09:20 PM
sbcvulcan's Avatar
sbcvulcan
the way u describe it well thats what i was expecting. I put those screws and grommets in tightening only the bottom as instructed at first, then tightened top with windshield in grommets, had to loosen one on bottom to align. Put lock pin in place, under mushroom cap screw head.
went to undo, no slide and glide for me.
maybe just need to try again... what seem so simple......
Old Aug 26, 2013 | 09:47 PM
GLW Mike's Avatar
GLW Mike
Mine was tough at first but, I just squirted a little silicone spray on the grommets. Comes on and off great. A little squirt inside the grommet grove and you should be all set.
Old Aug 26, 2013 | 09:55 PM
sbcvulcan's Avatar
sbcvulcan
I can try that for sure. Thanks!
Old Aug 27, 2013 | 04:59 AM
mr_brakke's Avatar
mr_brakke
goes on and off very easy like FXDWG12 ii am worried someone else will take it off..
the rubbers need a spray tho cuz they seem to dry out
Old Aug 27, 2013 | 05:11 PM
wiktor's Avatar
wiktor
Mine likes to chew up the rubber grommets. Tried to lube them once but then windshield would come loose with just a bump from behind the top and I was worried with it coming loose from negative air pressure like behind a truck. Wish I would have went with a National Cycle windshield.
Old Aug 27, 2013 | 07:44 PM
AHH's Avatar
AHH
Memphis shades just installed -- easy on and off -- bottom of shield needs to be spread just a tad (maybe an 1/8") before putting on, and a little extra care taking it off to not scratch the paint.
Malleck
Apr 25, 2026 11:36 AM
Steve Sportster
Mar 9, 2019 07:30 PM
Berick
Mar 19, 2015 07:09 PM
psidaho
Aug 8, 2014 05:35 PM
AmericanMuscle
Sep 19, 2012 05:30 PM
