Transmission issue
Old Aug 27, 2013 | 12:57 AM
brymer84's Avatar
brymer84
Default Transmission issue
On my way back from Sturgis my shifter started acting up. When I change gears my shifter doesn't pop back to be engage in the next gear. I have to manually move the shifter up or down about 1/2 an inch for the shifter to engaged to change gears. Btw 6 speed with only 9,000 miles.
Old Aug 27, 2013 | 04:59 AM
Gman in NC's Avatar
Gman in NC
Pretty common. The shaft on the front shifter is dirty/corroded. Take it apart, clean the shaft and lube it.
Old Aug 27, 2013 | 09:58 PM
brymer84's Avatar
brymer84
The dealer told me they would most likely have to tear down the entire transmission. I truly hope they are wrong. I will try your suggestion. Thank you. Has anyone else experienced this ?
Old Aug 27, 2013 | 11:13 PM
Bluehighways's Avatar
Bluehighways
Like Ivory Soap, there's a 99 and 44/100th percent chance that Gman has the answer!
Old Aug 28, 2013 | 02:08 AM
VETERAN75's Avatar
VETERAN75
Heck yeah man. Check to make sure all linkage is clean and moves freely before taking it in.
Old Aug 28, 2013 | 06:20 AM
jsimmons6703's Avatar
jsimmons6703
I'll 2nd that.. Happened to me.. A little WD40 and all is well
Old Aug 28, 2013 | 06:32 AM
BFMC Gadget's Avatar
BFMC Gadget
Easy check is to remove the rod from the shift lever at the trans and see how well the foot lever works. If it is real stiff pull it and clean and grease the bushing. If it is loose and free then the trans is the issue.
Jimmy
Old Aug 28, 2013 | 07:05 AM
fdb2007's Avatar
fdb2007
Another vote for clean and lube the linkage as Gman said. While not impossible for it to fail, the tranny in these are a lot like the old Muncie 4-speed--they just last. Please let us know what the fix was.
Old Aug 29, 2013 | 03:02 PM
brymer84's Avatar
brymer84
Clean and lube did the trick. Thanks boys that could have be a costly visit to a dishonest dealer.
Old Aug 29, 2013 | 03:16 PM
Gman in NC's Avatar
Gman in NC
Glad all went well.
