Shotgun shock question
yup no heat needed just a short kick with the heel and they cracked loose
My usual setting for riding solo is:
Both switches up until at maximum height then let the compressor run another 10 seconds or so.
Then rear switch down in short bursts 1-2-3-4. This usually puts the top of my fender right above the top of the rear rim. You can also just hold the rear switch down to a pre-determined height. The 1-2-3-4 works good for me. It's pretty reliable and I can do it without looking at the rear tire.
Then I usually give the front switch a quick down to let a very small amount of air out of the rebound. This will soften the ride up just a hair.
This is my usual solo setting for most applications. This lowers the bike a little so it looks cool and still provides a very comfortable ride. This will vary with each person depending on several factors.
Hope this helps and enjoy the ride!
One nice about this bike is it's strictly solo, so I don't have to worry about multiple setups for say, two-ups.
I figure once I get "in the zone" it'll likely stay there except to slam it for showing off purposes.
I talked to JD earlier today for a little feedback on the subject (I just wanted to make sure I was doing it right), and it turns out I have a newer configuration that was mentioned in the instructions. These are all momentary, up AND down - with center off, as opposed to the older "lock on" switches he used to use.
He gave me an instant walk-thru, as though he just dropped whatever he was doing just to tell me about it.
"Now try this..." "This is what happens when you do this..." etc...
And we also determined one of the switches might be bad as it felt a different than the other and didn't always "connect".
Took him all of two seconds to say he's sending out a new set of switches and the harness...
Un-freakin'-believable.
