Hello All, Got a 0-ring question. Does the primary,trannie, and oil tank all have the same size o-ring for the drain plugs? Also does anybody know the size of them. Thanks in advance
I copied this from a post on this forum for future reference. I believe it may have been in the touring section. I'm not sure how this translates to different years and/or models.....
Harley oil plug/tranmission plug/ primary case plug O-ring HD part #11105
The cross reference is #013, the o-ring size is 9/16 o.d. x 7/16 I.d. 1/16 cross section (thickness).
Viton is best but Buna-N will do
Yep, your right. 7/16x9/16. The hardware o-rings work just fine for drain plugs.
