Screaming Eagle oilpump and camplate
Old Oct 3, 2013 | 02:39 PM
billytwobags's Avatar
billytwobags
Default Screaming Eagle oilpump and camplate
Hi folks has anyone upgraded to the Screaming Eagle oil pump and cam support plate if so what is the max pinion run out . Do HD give a max on the run out I am thinking of up grading my 06 FXSTI
Old Oct 3, 2013 | 02:51 PM
Radimus's Avatar
Radimus
I have a friend that was trying to sell me on one of these as well. He was offering it to me at a great price as well as free installation.... although I'd still bring the beer
Old Oct 3, 2013 | 04:10 PM
FXDWANTARACE's Avatar
FXDWANTARACE
Stage III
Default They Sell 1000s BUT
They sell 1000s of them but they are not necessary! The only time you need the oil pump is if you have pressure problems. I am running a stock oil pump with the stock plate with GEAR Drive. WOODS TW68G GEAR DRIVE CAMS, WOODS WDL-1012 DIRECTIONAL LIFTERS, COMPRESSION RELEASES 11-4 COMPRESSION 3001 TC CYLINDER STUD KIT. The key on any TC is getting rid of the darn chain drive when you can afford to. I made mine brake Twice with in warranty .. Some bikes have the oil light come on at idle. That is not necessarily a bad thing. As long as you have 35bs at running rpm all is well. Yes a Gear drive is slightly loader, but you only need to replace is ONCE... Have a Good One BILL
Old Oct 3, 2013 | 04:17 PM
QC's Avatar
QC
I have the SE plate and pump on mine. Did the whole thing-cams, hydraulic tensioner upgrade, etc. What year bike are you running? I think up to '07 max runout from the factory was .005. The plate and pump are a worthwhile upgrade whether you do cams and tensioners or not, IMHO. But you may as well do cams while you're in there. Just make sure you get a kit that includes the roller type chain for the back side of the plate as well. The basic H-D kit does not come so equipped. Took me about 5 hours, taking my time and double checking everything, never had done it before.
LazySundays
Sep 13, 2014 06:55 AM
sjbodie
Engine Mechanical Topics
Mar 24, 2014 07:43 PM
Lundee
Exhaust System Topics
Feb 8, 2012 09:29 PM
riden2low
Jul 20, 2011 02:20 PM
Good_Apollo
Jul 7, 2011 07:11 PM
