Applying touch up paint
Old Mar 10, 2007 | 12:30 PM
WARG's Avatar
WARG
Default Applying touch up paint
Hey guys,
Getting ready to apply my touch up paint to my rear fender that I scratched. I have a couple questions:
Do I need to clean the area, like with alcohol first?
Should I sand the spot? The spots are only about the size of a BB.
At 75 - 80 degrees, what should the cure time be?
After applyingeach coat, do I need to sand it a bit before applying the next coat.
I have 3 coats to do, a Fire Red base coat, a Brandywine Sunglo top coat, and then the clear coat.
Any help will be appreciated as usual.
WARG
Old Mar 10, 2007 | 12:38 PM
fbhawg's Avatar
fbhawg
Default RE: Applying touch up paint
You sound like a brave man. Hope it works. I'd take it to a pro. Mine looked terrible after a guy said he could do it on mine. I got my tank and front fender back to perfect for $300.
Old Mar 10, 2007 | 12:55 PM
DaveJ's Avatar
DaveJ
The guy that painted my bike is coming over this afternoon to visit his bike (it's stored in my garage over the winter). I'll bounce this question off him and get some pointers for you.
[align=left] [/align]
Old Mar 10, 2007 | 02:40 PM
nikonf8's Avatar
nikonf8
On a tiny spot like a bb unless I was showing the bike it would not be a big deal. An old trick some guy told me once and I have used quite a few time is pull a match from a match book use the torn end to pick up a little paint and then just touch it. I mean if your looking to get back to the factory finish that would be a major project but if looking to have it not be so noticeable the match trick works
Old Mar 10, 2007 | 03:42 PM
WARG's Avatar
WARG
Just looking to get it not so noticable.
Old Mar 10, 2007 | 07:14 PM
purple haze's Avatar
purple haze
Also I did what you are doing to my wife's GX-470 S.U.V, it's PEARL WHITE, 3 color's I bought, bace coat, pearl to go on bace then clear, very small rock chip, but I was going to make disappear!!!!!!!! that spot now stick's out like turd in punch bowl!!!! so the next time another rock cheap popped up, so I just cleaned area and used bace coat only which was white color of car, you must really look to see it, but just my thought's ,could be wrong, your bike, it's kind of like small stain on carpet, use to much crap, next timestain is big as plate. PURPLE HAZE. GOOD LUCK.
[IMG]local://upfiles/24725/6979D4CCC1314A9E927484238967FCDF.jpg[/IMG]
SoCalMike
Jan 13, 2014 10:21 AM
crazy_walt
Jun 27, 2011 02:48 AM
goose246
Dec 6, 2009 07:10 AM
pr_capone
Jun 29, 2008 08:24 AM
Garbock
Oct 3, 2007 02:46 PM
