Possible bent handlebars/forks, how do i know?
Old Nov 1, 2013 | 09:36 PM
Matt K's Avatar
Matt K
Default Possible bent handlebars/forks, how do i know?
I laid the bike down going about 20 mph last month. it just basically tipped over on the left side. I picked it up and rode it home, but as i was riding home, i noticed the left side of the handlebars were pushed up and skewed the handlebars from being straight.
i just got all the parts in the mail and swapped out the old risers (a chunk broke off and couldn't screw into it) as well as put some beach bars on. took her for a ride today and the handlebar still seemed to be off-center.
Could this be that that risers arent in straight or could it be a bigger issue such as my forks?
Old Nov 1, 2013 | 09:47 PM
Matt K's Avatar
Matt K
found this image off another thread, this is exactly what my bars look like, and i also just threw in polyurethane bushings, not sure if it makes a difference in alignment however
Old Nov 1, 2013 | 10:09 PM
RANGER73's Avatar
RANGER73
If that's exactly what it looks like. I think it's the risers. Try loosening the riser bolts and twist.
Old Nov 1, 2013 | 11:17 PM
wonson3's Avatar
wonson3
as above said
Old Nov 2, 2013 | 07:04 AM
08Nighttrain's Avatar
08Nighttrain
It's most likely the risers loosen them twist till straight and have buddy tighten them while you hold handlebars straight. It helps if you slowly tighten each bolt just a couple turns then switch back and forth till they are torqued properly.
Bill wallace
Shovelhead
15
Aug 16, 2017 07:27 PM
f3fidy
Apr 14, 2013 08:18 PM
CSS_FXD
Jul 13, 2011 11:16 PM
AstroGlide
Feb 1, 2010 06:48 PM
09fatbob
Sep 25, 2008 05:12 AM
