Automatic compression release
Old Dec 16, 2013 | 08:03 PM
flipbel's Avatar
flipbel
Default Automatic compression release
Other than a compression test or removing them, how would I know if the acr are working? Will I get a check engine light if they are not working?
Thanks
Flipper
Old Dec 16, 2013 | 08:38 PM
bigblock59's Avatar
bigblock59
continuity test
Old Dec 17, 2013 | 03:32 AM
tbonetony06's Avatar
tbonetony06
Trust me, with an open hole in your heads, you'll know. Also, you must have motor work done to have them and if they are not working when starting the bike it will grunt pretty good for you, especially when doing cold start ups.
Old Dec 17, 2013 | 06:44 AM
Mikeskins's Avatar
Mikeskins
He has a 2013 fat boy. When I had my motor work done to my 2013 fat boy I found out that 2011+ I believe come stock with ACRs.
Old Dec 17, 2013 | 08:52 AM
tbonetony06
OK but regardless it won't run if they are stuck open and it will grunt pretty good on cold starts if they won't open.
Old Dec 17, 2013 | 02:58 PM
flipbel's Avatar
flipbel
Thanks for ur input. Does anyone know if a failed acr will produce a code?
2013 fatboy
Old Dec 17, 2013 | 03:24 PM
screaminroadking's Avatar
screaminroadking
I would rather have manual c.r. I have factory a.c.r. on my 110 and have had a couple of issues with them not working. They have since been "fixed" but still not convinced they won't crap out again. I would sacrifice burnt fingertips any day. At least you know they are working.
the warden's Avatar
the warden
As you are riding a '13 I would make any issue i might be having with the ACRs the dealers problem under warranty.
Old Dec 17, 2013 | 03:51 PM
flipbel's Avatar
flipbel
No issues just want to know
Old Dec 17, 2013 | 07:39 PM
tbonetony06
I would say that since it is stock and electrical it would give you a code. That is purely a guess. Side note, I have manual on my heads. I have seen guys have issues with the ACR's, I never have. Just my .02 on the issue.
