Progressive drop in vs. regular
Old Dec 19, 2013 | 08:52 PM
BakoOil82's Avatar
BakoOil82
Default Progressive drop in vs. regular
Hey guys anyone have pros and cons of going with the drop in Progressive kit vs the regular lowering kit? I plan on doing the swap when I pull my tubes off to PC the front end and lowers so that's no issue. Looking at the 2" drop version.. Thanks
Old Dec 19, 2013 | 10:31 PM
ShortsNSandals's Avatar
ShortsNSandals
I have the drop in and the performance over stock is amazing. Front end doesn't dive going into corners or hard front braking, yet soaks up all the bumps as good as stock. I also dropped it 1.5 inches.
Old Dec 20, 2013 | 04:54 AM
jreichart's Avatar
jreichart
I went with the full kit. They both accomplish the same thing, but I would bet the full kit rides a little better than the drop in. It accomplishes the drop with additional damper springs combined with a shorter main spring, rather than with a shorter main spring alone. Just seems like all the parts would work better together when they are all designed to work together. It's a bit more work to install as well, but worth it IMO.
Old Dec 20, 2013 | 05:24 AM
Rodzilla6's Avatar
Rodzilla6
I put the 422 progressive in the rear of my bike with awesome results. I put the new spring kit from progressive in the front and it made a HUGE positive diff.!! It only cost 90 bucks for the front, 1 hour install. My mechanic buddy measured the handlebar height to floor when the bike was sitting/no rider, then he measured with me sitting on it...after the progressive install, he measured again...when I sat on the bike with the "challenged" stock front springs, the bike went down 2" with me sitting on it...with the progressives it only sagged 1/4" with my fat butt on it!!!! Rides like a dream, better handling. I also used the screaming eagle heavy duty fork oil and love it. I WISH I HAD DONE THIS UPGRADE ALOT SOONER...
Old Dec 20, 2013 | 02:10 PM
XARAN's Avatar
XARAN
IMO the better way to lower the forks is with the regular kit over the drop in kit. Using the regular kit shortens the travel distance for the sliders (by adding a 1" or 2" spring spacer that stops the tube from fully extending) and allows you to adjust the amount of preload and your SAG in the forks. Using the Drop In kit is effectively just making a known amount of sag in the front end to lower the forks, with the Drop In kit you can not make correct adjustments to the spring pre load with out effecting the ride height . if your taking the lowers off anyway do it the right way
Also if you want to really improve the forks look into either Mono Tubes or the fork kit and add Race Tech Gold Valves to the Dampers to improve the dampening.
Also use a better Fork Oil , I like SE Fork Oil
Old Dec 20, 2013 | 02:22 PM
rooti's Avatar
rooti
That's the best advise so far...while your in there, put in the ricor intimidators and amzoil shock therapy fork oil. You will not believe the difference...
Old Dec 20, 2013 | 04:31 PM
Hogpro's Avatar
Hogpro
Former Sponsor
I had the drop in's in my softail. I like them but I put mono tubes (also a Progressive product) in my new bagger and I like them even better. They are a little more money but well worth it to me. Stiffer than the springs, yet they ride much better.
Old Dec 20, 2013 | 07:59 PM
dennyo's Avatar
dennyo
I'm thinkin bout dropin my front end down 1in. ....
Old Dec 20, 2013 | 10:43 PM
ShortsNSandals
Let me clairify what I have. I have mono tubes which I thought you were referring to as drop ins. These come with a plasitic c clips that you add or subtract to your desired ride height. These ride way better than a standard drop spring.
Bobbed Out
May 18, 2014 05:01 PM
condition1
Dec 12, 2012 07:40 PM
JaronB
Jul 8, 2011 09:54 PM
Lilman
Mar 29, 2011 04:33 PM
hippityhog
Apr 20, 2006 12:48 PM
