No front fender - do I need a brace?
Old Nov 26, 2020 | 06:40 AM
Bone Doc's Avatar
Bone Doc
Originally Posted by Jeffrey Conner
That should not happen. The fender is not structurally a part of the forks or the wheel . It is just a bolt on device to deflect water. I would check your tire balance and your alignment on the rear tire. If you tightened your chain or belt and on one side is off it could translate into a wobble. Or a worn bearing will do this also. But not riding without a front fender. Dont ride it until you figured it out. You dont want to get the death wobble.
Jeffrey, welcome to the forum from central Texas.
Whoever you are responding to hopefully has it all figured out by now. This thread is almost 7 years old.
Old Nov 26, 2020 | 07:17 AM
PaperBag's Avatar
PaperBag
LOL! Zombie alert!
Years ago I rode a BMW R90S and had a San Jose fork brace to stiffen up the front end. I had traded up from an R90/6. Maybe it was the bike, but I could feel a difference. The fender is either plastic or thin metal attached by a few bolts with maybe a metal bracket. A proper brace is steel, rigid, attached directly to the fork legs, and doesn't flex. Um, I did push that S pretty hard...
Old Nov 26, 2020 | 07:52 AM
60Gunner's Avatar
60Gunner
Originally Posted by jreichart
Same here, no difference at all in regards to front end stability.
Since this thread has been awoken, the fender doesn't do much in the way of support, but even with it, any bike would benefit from an added fork brace. The stability of a good fork brace is immediately noticeable. My fender came off the Sporty when I had it. Looks much better.
Old Nov 27, 2020 | 11:53 AM
camomanofcranham's Avatar
camomanofcranham
I'm not inclined to think a brace is needed as the fender is made from thin gauge steel and woundnt give a great deal of support. It maybe an idea to check the front end over wear or even damage as you shouldnt get those kind of symptoms when riding...
CLL375
Good Or Bad Shopping Experiences At HDF
Jun 3, 2014 03:54 PM
nefdez
Jan 18, 2013 01:52 AM
low_n_slow
May 30, 2009 08:17 PM
rounder
Nov 5, 2008 05:00 PM
Beach Bum
Pacific
Aug 25, 2008 11:43 AM
