Around 40 degrees my bike started to crank sluggish. A battery with better CCA helped. Keep in mind that your bike has to turn over that 20/50 motor oil and that crap is like syrup when it gets colder out. Your manual tells you when you should change the grade of oil to help reduce cold start issues. I got some 10/40 but I still haven't used it yet.
I run Royal purple 20/50 and with the better battery, I haven't had an issue with it cranking over. Also, I NEVER use a tender. I start it and I run it at least 3 times per week. When the roads stay icy and snow covered, I start it and ride it anyway. Let it warm up until it idles down to 1,000 rpm, put 15 miles on it and you'll burn the condensation out of the oil.
You will find that the oil you run has a lot to do with how it cold starts. Also, I start mine in neutral. I doubt the clutch/primary drag accounts for much on cold starts but it seems to help a little.
This is a very opinionated topic and this just happens to be my opinion.
Originally Posted by deenew33
Thanks guys...It was around 40 degrees this morning...sluggish start but it started.. took it to the Harley dealer this morning they checked the battery with meter, they said battery is good. I bought some fuel stabilizer to see if that helps. So you guys think I should replace the battery anyway?
There are a lot of dynamics involved in starting a bike. The ECM should have an enrichment setting along with a AFR temperature correction. You did not say whether you had a stock setup or if it is something other than stock.
I have a TMAX in my bike. I had it dyno tuned, but the tuner never looked at cold startup. No way he could, it was summer. About 6 months later, I noticed it did not do well on cold starts. I had to adjust the AFR temperature correction. Even now, when it is that cold I have to give it a little throttle during startup. No throttle required when it is warmer.
You are not trying to start it with the tender hooked up are you?
no sir i do not try with it hooked up....I have a power commander hooked up with the screaming eagle air filter installed...with the vance and hinds slip-ons.
Didn't think about that..didnt think that mattered. I also was told try to get a heater for my garage....
Seems like a common theme on this thread. My 2014 Heritage with ~21,600 miles is hard to start when the bike is cold and has sat for ~ a day. No "clicking", just a draw down of the battery. If I let the bike sit for several minutes, it will eventually start. The rest of the day it starts fine. New batteries do not seem to help. I now have a new H-D Lithium battery that indicates fully charged (all three blue dots lit) and still performs the same as the lead acid batteries. I let the lithium battery "warm up" for a minute or two.
