Spotlight Mod
Old Mar 10, 2014 | 07:06 AM
SBates08's Avatar
SBates08
Default Spotlight Mod
Hey guys I need your help. I've searched this but to no avail. I have a 2006 Heritage Softail and I wanna wire the spots to stay on when headlight is on bright. I've done the free Mod on my Limited but since the Heritage doesn't have an auxiliary switch I can't figure out how to make this work. Is this even possible to do on the Softails??? Thanks in advance.
2010 Limited with some stuff
Old Mar 10, 2014 | 11:25 AM
jam436's Avatar
jam436
Harley makes a kit for that.
Part number 69200442 - $29.95
INDEPENDENT CONTROL AUXILIARY LAMP WIRE
HARNESS KIT
Maximize your nighttime view down a lonely stretch of back
road. This simple-to-install wiring harness permits independent
control of your bike’s auxiliary lamps, and allows the
lamps to be switched on when the headlamp is in either the
low or high beam setting.
Fits ’96-later FL Softail and ’97-’13 Road King® models
equipped with auxiliary lamps.
Kuryakyn offers something similar as well:
http://www.kuryakyn.com/Products/428...g-Lamp-Harness
..as do a few other places, like Surdyke.
Old Mar 10, 2014 | 11:33 AM
SBates08's Avatar
SBates08
Ok thanks Jam. I thought there may be a way to do it like I did on my Limited.
Old Mar 10, 2014 | 11:44 AM
jam436's Avatar
jam436
Just bear in mind that it sounds as though you may need a switch for the aux. lights to use the H-D kit, which you say you don't have.
The Kuryaykn kit OTOH sounds like it doesn't matter, so you may want to check that out.
Old Mar 10, 2014 | 12:03 PM
SBates08's Avatar
SBates08
Ok thanks.
Old Mar 10, 2014 | 12:17 PM
SBates08's Avatar
SBates08
I found a thread that says there's a keyed hot wire (orange&white) that is unused under the tank that can be used for a hot wire for the auxiliary lamps. I'll give this a try.
Kayakeur
Electrical/Lighting/Alarm
Aug 31, 2015 08:10 PM
Ripper13
Apr 24, 2015 10:42 AM
MoChrome
Touring Parts
Apr 27, 2013 09:12 AM
MoChrome
Softail Parts
Feb 17, 2013 05:40 PM
Badfinger
Jan 4, 2013 09:52 AM
