Anybody own a Pitbull Motorcycle lift??
Business is a little slow today, so I'll jump into the fire.
I will assume you don't have any jack now.
Here's my opinion:
Harbor Freight steel/Sears Red Jack:
Pros: solid frame, low price (~$90), fairly stable, gets the job done
Cons: Asian made, cheap bottle jack, limited warranty, weight makes it difficult to hang on the wall
Harbor Freight aluminum/Sears Yellow Jack:
Pros: fairly stable, light weight, can easily be hung on the wall, gets the job done
Cons: Asian made, seems a bit to lightweight, medium priced (~$180), cheap bottle jack, limited warranty
Pitbull:
Pros: USA made, solid built, extremely stable, lifetime warranty
Cons: High price (~$500), takes up a lot space, too heavy to hang on the wall
JS Jacks:
Cons: High price (on sale now for $400), takes up a lot space, too heavy to hang on the wall
Final conclusion:
In my opinion the Sears red jack is the best jack out there for the average user. I had that jack for a year and had absolutely no problems with it. The primary issue I had was that it was just too heavy to hang on the wall, but that's what made it so stable. I came across a Sears yellow jack for $65 and couldn't pass up the deal. After comparing the red to the yellow, I sold the red for $50 only because I could easily hang the yellow jack out of the way however I do miss the stability of the red jack. If money and floor space wasn't an issue; based on all the reviews I'd buy the JS Jacks.
So getting back the original question; if I could get either the JS Jack or Pitbull for ~$200 I'd have to buy either. For more than $200, I'd stick with the Sears red jack.
Motorcycle Lift Comparison - YouTube
I have a J&S, and it's everything they say it is. When not in use, I just roll it under the workbench, tighten the brake, and that's that
But no matter what jack ya have, here is a tip..When leaving your bike elevated on the jack, make sure you engage the safety bars and release the pressure off the jack...I usually release just enough pressure to relieve the stress from the jack, but then re tighten it so that its a last ditch effort in case something else fails and the jack starts to decend on it's own
I know quite a few people that own the Harbor Freight jack and have had no problems with it at all, I must have just got a bad one.............
