Battery indicator does not light
Old Mar 12, 2014 | 03:29 PM
pankol's Avatar
pankol
6th Gear
Default Battery indicator does not light
I have problem with my Rocker C 2008, after the winter time my battery charging LED indicator does not working. If I switch odometer to service mode all indicators lights also battery indicator, but in normal operating not! I afraid that is someting bad wit my charging system, but I measure voltage on iddle speed is 13,70 V in my opinion correct. Before winter time I was ride with very bad battery condition, my by some electronic unit can be broken? Now I was exchange battery to new and problem is still exist. I no idea wats heapen, I was checked error in ECU by SE PRO Tuner and memory is clear?
When I swith ignition to on (not start engine) battery indicator not light?
I supose that battery indicator signal comes from ECU to ODOmeter by CAN bus signal, it's true?
fignuton
Oct 11, 2015 03:24 PM
curtycscied
Welcome Area Only
14
May 3, 2013 09:10 AM
Curious.Yogurt
Jun 26, 2009 10:26 PM
Nickpisp
Apr 11, 2009 08:13 PM
SilverFat Boy
Electrical/Lighting/Alarm
Jan 8, 2009 04:00 PM
