Battery Or Something Else?
Old Jan 7, 2009 | 07:17 PM
SilverFat Boy's Avatar
SilverFat Boy
Stage I
Question Battery Or Something Else?
I have a 2004 FatBoy. I allowed the battery to discharge. I hooked up my trickle charger for a couple of days and when I turned on the ignition key the headlight was very dim and it would not even try to crank. I hooked up my regular battery charger to it and left it overnight, the next day when I turned on the ignition, the light was brighter but the speedo background light started blinking and the engine would not crank. I checked the battery condition with my tester and it read 13v, with my battery charger hooked up it read 15v. I left it charging overnight again, but the next day I had the same results. I did notice that my battery charger was showing that the battery was not accepting any current? I am at a loss as to what is happening here. Any thoughts?
Old Jan 8, 2009 | 01:42 PM
nocarb's Avatar
nocarb
When you read 13 volts, how long was it after you disconnected charger? Need to let surface charge go away before taking a voltage reading. Is this the original battery? If so probably due for a new one. Would not hurt to check all connections just to be on safe side.
A battery can get to the point where it will no longer take a charge. You may be at this point with a 5 year old battery.
Old Jan 8, 2009 | 02:43 PM
hotrodsandharleys73's Avatar
hotrodsandharleys73
New battery.
Old Jan 8, 2009 | 03:48 PM
texas tom's Avatar
texas tom
Hook up a meter to the battery then try to crank it,bet it goes to allmost nothing,these batteries dont like to be completely discharged they allmost allways need replacing...
Old Jan 8, 2009 | 04:00 PM
retiznapuerco's Avatar
retiznapuerco
5 Year Battery? wow, It took my first one less than 2 years to do what yours is doing. Time for a new one....
cgmartine
Electrical/Lighting/Alarm
19
Nov 11, 2020 10:56 PM
ElectraJim
Jul 12, 2018 02:43 PM
NKy Ultra
Dec 28, 2016 05:17 PM
Theakerr
Sep 28, 2012 04:51 PM
Asclepeus
Aug 11, 2012 08:21 PM
