how do i remove fuel rail to get to injectors?
Old Mar 15, 2014 | 10:13 PM
txphatboy's Avatar
txphatboy
Default how do i remove fuel rail to get to injectors?
Trying to replace stock injectors for a littler more flow. I know - get a service manual. Dealer does not have one in stock and I need to swap out injectors for a tune next week, so I could use a little help, please. I searched and I found a few posts about pulling tank, etc. I pulled tank, intake, unplugged connectors, removed fuel rail bolts, but do not know how to remove fuel rail on top of injectors. No post I found on removing injectors even mentions the fuel rail, which I don't understand, since you cannot get injectors out with it in way. I assume you have to remove the clips from the top of the injectors that connect to the fuel rail. I would really appreciate any tech help in removing the clips/fuel rail. And I promise I will get a service manual asap. Thanks.
Old Mar 16, 2014 | 10:19 AM
txphatboy's Avatar
txphatboy
I bought an electronic manual last night, but damn thing won't open on computer. Somebody out there with a manual that can copy how to remove fuel rail/caps on top of fuel injectors??
Old Jun 30, 2017 | 02:12 PM
SofttailBob's Avatar
SofttailBob
6th Gear
I am new to the forums and I just came across your post about removing the fuel rail. I have to do the same thing on my '01 FLSTCI to get at the fuel injectors. How did you do it? I was going to remove the entire induction module because the shop manual makes it sound easy, but I can't get at the 4 allen screws holding the intake manifold flanges. So, before I unscrew the 2 fuel rail screws, I figured I would ask somebody who has experience with it. Yours is the only post that comes close to what I need advice on.
Old Jun 30, 2017 | 08:06 PM
lh4x4's Avatar
lh4x4
I put new injector sets in two engines last year. It was easy but then the engines were on my bench. Access is the key.
Wobble head allen wrenches will help with the four screws holding the manifold in. Get the manifold out and everything else is easy. Just looking at it in your hand will tell you the steps needed.
Old Jul 1, 2017 | 12:54 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
There's thing thing called a Service Manual. I suggest you buy one before you go any further!
Old Jul 1, 2017 | 05:47 AM
SofttailBob
6th Gear
I agree with OldEnuf about the service manual. That is the first thing I bought when I bought the bike. Section 9 goes into great detail about EFI. It does seem that when it talks about anything related to the induction module, e.g. fuel injectors, the assumption is that the engine is off the bike.
I am looking to get at the injectors with the engine on the bike if possible. Bike is an '01 FLSTCI.
Old Jul 1, 2017 | 06:21 AM
TeaRunner's Avatar
TeaRunner
The electronic version you got should be a pdf, download Adobe acrobat to open it.
Old Jul 1, 2017 | 07:23 PM
OldEnuf2NoBtr
HD Forums does not condone the use of illegal bootleg copies of the MoCo's copyrighted material.
Old Jul 1, 2017 | 09:28 PM
SofttailBob
6th Gear
FWIW,
I removed the top engine mount bracket and that gave me the access that I needed.
Old Jul 1, 2017 | 09:32 PM
SofttailBob
6th Gear
Why all the posts about the service manual in this thread? Is it an auto response to OP?
I bought the hard copy Service Manual (Part number 99482-01A) and the Parts Catalog (Part number 99455-01) from the H-D dealer way back in 2000 when I bought my bike.
Big-dawg
Jun 10, 2018 04:29 PM
Skyking75
Oct 18, 2017 06:49 PM
Twospot
Mar 3, 2016 03:57 PM
LeFat1
Carburetor Related
Mar 3, 2014 05:06 PM
EasternSP
Jun 25, 2012 07:07 PM
