OEM Passenger seat unglued
Old Mar 25, 2014 | 04:38 PM
NYC_Breakout's Avatar
NYC_Breakout
Default OEM Passenger seat unglued
I have a 2014 Breakout and the glue on the passenger seat pad separated after I gave someone a ride. Any suggestions on how to reglue without disassembling? Not sure if due to the cold. Don't think the dealer will warranty it.
Old Mar 25, 2014 | 04:57 PM
BigMESA's Avatar
BigMESA
I'd take it back due to manufacturer flaw and make them warranty it. At least try before you try and fix it yourself and void whatever warranty it may have.
BUT
If you must dabble then this is what I'd recommend:
http://www.homedepot.com/p/3M-17-6-o...0-24/100151277
or
http://www.homedepot.com/p/DAP-1-gal...7534/203661572
Both work very well IF applied properly. I've used both to re-upholster my boat and I use the 3M spray on the soles of shoes that start to separate with no problems. You just have to make sure after you apply the glue to both sides of whatever you're sticking you let it sit and get tacky for a bit before you press them together to get the best bond. I usually put a towel over something small and wrap the living hell out of it with electrical tape to let it set up for a few days.
Old Mar 25, 2014 | 05:57 PM
oct1949's Avatar
oct1949
don't tell us n here, its still under warrenty... take it to your dealer and they'll fix it... if not then there are all kinds of good glues that will work to stick it back..
Old Mar 25, 2014 | 05:59 PM
NYC_Breakout
Thanks for the info.. I will talk to the dealer first, what can it hurt especially since I only need to take the seat in.
Old Mar 31, 2014 | 07:54 AM
NYC_Breakout
Went back to HD of LI and told them about the problem with the seat and they were great about it. They replaced the seat no questions asked.
Duke 13
Jun 22, 2016 11:13 PM
Dane M
Apr 3, 2016 06:35 PM
jmbear328
Jun 13, 2014 09:24 AM
EdAviles
Sportster Parts
May 13, 2014 08:15 AM
timbakersr
Jun 23, 2008 07:31 PM
