Air cleaner choices?
"Fits ’08-later Touring and ’11-later CVO Softail models
equipped with Screamin’ Eagle Pro High Flow 58mm
Throttle Body P/N 27713-08.
29400039 Chrome. $249.95"
I spent quite a while tonight withe Screamin' Eagle catalog and examined the "fitment" of every air cleaner in it. My ONLY 2 choices are two configurations of the Heavy Breather (regular and compact) and the Extreme Billet round air filter (first series in the catalog), and even there I had to be careful with the part numbers that actually work: just ONE chrome version and ONE black version. I'm going with the chrome Chisel version, pn 29400124.
Besides the 2 different colored versions of the Extreme Billet and the 2 versions of the Heavy Breather, there are NO other part numbers that actually are guaranteed to fit a 2014 Softail with a 58mm mechanical throttle body.
And by the way, even if the Ventilator would fit, it would not help. Underneath the cover on it, the outside facing surface of that air cleaner is STILL "sealed". It only draws air from its "perimeter". The Extreme Billet one on the other hand has a multi-sided air filter element, and the billet cover allows drawing air from OUTSIDE (i.e. from the right side of the bike) along with the hotter air on the perimeter, which itself is cooler than the air drawn by the stock "football" shaped cover air filter configuration from right between the cylinders.
I need to have it before my dyno tune on the 19th, so my local dealer is transferring it in from another nearby dealer, and I'll have it by Tuesday afternoon, so I'll have time to install it before the dyno tune.
It's hard to believe that out of the entire vast HD offering of air filters, if you want cooler "outside" air, you have a choice of only 4 total variants of 2 air filters.
At least they both LOOK good.
Jim G
On a previous '12 Ultra I installed the 2014 style Touring air filter outer cover with the forward facing vent over an existing Stage upgrade similar to yours, but with the shallower filter element. There's still some rear facing intake area, but the idea was to inject cooler air from the front. Off'd the bike before I could test.
I'd consider the Heavy Breather in your case if it were mine and I wanted a proven increase in power via the air filter. I fly with an approved K&N air filter element on an old Piper Cub. If they couldn't handle rain at 90 mph every small plane would be grounded on rainy days. I've yet to have an issue with rain induction in flight.
Have fun with your mods.
Jim G
Jim G
I was going to install an indoor/outdoor thermometer temporarily on the bike. Put the head on the bars where it can be seen, and run the outdoor probe and wire securely under the air filter. Note the temp differential at idle and while underway. Try to get them as close as possible via air filter design = as cool air as possible.
It can also be done via some aftermarket fuelers that read intake air temp, or using HD's digital Tech I believe.
The dual entry K&N that Jim's installing should help.
There are also dozens of different looks.
Probably most important, it is one of the few air cleaners that is not feeding hot oily air into the intake from the breathers.
If you ever have a chance to put your had near the air coming out of the rocker cases and being fed into the intake (without filtering) you might be surprised how much there is and how Hot it is.
The oily component of that oxygen depleted air is not doing your combustion chamber any good either.
DKCustomProducts.com
They all vent the air into the atmosphere and two of them have filters that absorb and hold the oil. When you wash the bike, you just spray those filters down too, and they are ready to absorb some more oil.
On the breather bolts the oil is stopped by the mesh screens and foam filter and then drains back into the engine...unless you have excessive oil carry over, in which case a fine mist will accumulate on the back plate of the air cleaner...but at least it's not getting into the combustion chamber building up carbon deposits.
With the Discrete System, you can put the filter anywhere you want it, the kit comes with 6' of hose. Below is a pic of my personal Softail, you can see the filter below my exhaust, near the back axle.
