Starting issue
Old Apr 18, 2014 | 07:15 PM
nocoast's Avatar
nocoast
Default Starting issue
1990 Heritage
Hey guys got a quirky issue going on. Sometimes, when I hit the starter button, nothing happens. No click, no engage, nothing. But when I sit on the bike magically the starter fires up when I hit the button. Obviously I have a loose wire but I thought the starter button wire goes from the hand control to the starter relay which isn't directly under the seat. Anyone have an idea where to start.
Old Apr 18, 2014 | 07:27 PM
the blob's Avatar
the blob
Id make sure batt. Cables are tight.
Old Apr 18, 2014 | 08:14 PM
threadstopper's Avatar
threadstopper
I'd go one step further and remove the cables and clean the terminals with a small wire brush and apply dielectric grease then re-tighten everything. JMHO
ride safe and have fun
Old Apr 18, 2014 | 10:09 PM
Sgt_Jim's Avatar
Sgt_Jim
both of those. i had an issue like that, was a loose battery cable. sounds like the pressure from your butt on the seat pushes the cable down. pull the seat and check.
Old Apr 19, 2014 | 11:30 AM
WildBill_50's Avatar
WildBill_50
In addition to the above check the other end's to the cables and make sure they are clean and secure.
Old Apr 19, 2014 | 12:18 PM
oct1949's Avatar
oct1949
since new in 07 the only time I had a miss and then she died.. Was due to Battery cable bolts loose at the battery.. tightened them up and nary a prob since.... Well till I had to replace the battery when it was 5yrs old.
blinkwatt
Feb 2, 2017 10:31 PM
Bohemian
Shovelhead
43
Jul 9, 2013 10:37 AM
Derv
Jun 29, 2010 01:04 PM
brwdarr
EVO
11
Jun 10, 2009 09:40 PM
ragingbull
Apr 2, 2007 11:17 PM
