Bike not liking a hot start.
Old Apr 21, 2014 | 01:49 PM
uklauren's Avatar
uklauren
Florida Crew Moderator
Default Bike not liking a hot start.
I have a 2002 Springer FLSTSi which has had trouble with a hot start a couple times. It starts great cold but on occasion when I stop for a few minutes (gas, waiting for somebody) it turns over but won't fire up. It seems to on the second or third try.
It has just had a major 10k service though it's closer to 50k miles though this has happened once before and twice since the service. I bought the bike this past January so I don't know whether it's the battery that could be nearing replacement or something else. I'm becoming nervous to take it for a long ride and need to stop for gas and it won't start.
I'd be grateful for some suggestions.
Old Apr 21, 2014 | 02:36 PM
creed0423's Avatar
creed0423
I have a 03 Deuce and mine also does this. I just give it a lil bit of gas and it will start the first time. Unforantly i also do not know why this is. Hopefully one the guys that do know will chime in soon..
Old Apr 21, 2014 | 02:40 PM
rooti's Avatar
rooti
I would load test your battery. Mine did that but stopped once I replaced my battery and it was only 2.5 years old.
Old Apr 21, 2014 | 02:50 PM
Mike NY's Avatar
Mike NY
Hot starts are usually an issue in high compression motors. When I did my upgrade to 95", I had the Heads worked that brought the compression up so I also had them add Compression Releases. On Hot Starts I always use them.
Mike
NY
Old Apr 21, 2014 | 02:53 PM
DDuess's Avatar
DDuess
Make sure all connections for ignition are clean and tight. My deuce did this, when cranking, and voltage dips low enough, there isn't any spark.
groove
Sep 12, 2016 07:58 AM
ILMFBL
Sep 4, 2014 04:11 PM
PigInaBlanket
Feb 19, 2013 09:08 PM
lowrider56
Mar 21, 2012 05:43 PM
rnl_1200C
Jan 6, 2009 03:02 PM
