07 Deluxe Fuel Pump /ECM ?
Old Apr 29, 2014 | 07:02 PM
drailedin79's Avatar
drailedin79
Stage I
Question 07 Deluxe Fuel Pump /ECM ?
I washed my deluxe the other day with hard water , (well it was free) after I finished the fuel pump wouldn't come on ? it clicked was all ? After some help from my nephew and his electrical tester he had we had everything off and plugging things back in one at a time trying to find the issue? We found that the ECM fuse had blown? So after we plugged a mini 15 amp back into the ECM fuse slot then turn the run switch on (handle bar) The pump kicked on for just a second? then it popped the ECM fuse again??? He came to the conclusion himself that maybe the ECM had went bad? I've talked to several people and they all think it could several possible scenarios ? Either the Run or Kill switch went bad? Or the fuel pump is bad and kicking the ECM fuse?(but the fuel pump fuse doesn't?)
Or it is the ECM that went bad ??? Anybody got an idea or ran into this situation with theirs sure would be of help Thanks David
jlsmthrs97
11
Jun 12, 2022 02:31 PM
AMB2710
Oct 11, 2021 10:45 AM
LunchBreak35
16
Oct 14, 2017 07:35 PM
Brad223
Oct 20, 2010 12:50 AM
sicksuperglide
Jan 2, 2009 09:17 AM
