Half helmet neck strain
Old May 4, 2014 | 04:32 PM
ktb11's Avatar
ktb11
Default Half helmet neck strain
I have a basic harley brand half helmet and when I hit 50+ it picks up all of the wind and I have to force my head to stay straight which in turn strains my neck muscles (I'm not running a windshield). Does anyone have any half helmet recommendations that won't give me this problem? Mine sits fairly far up on my head. Perhaps something with a lower profile with more contoured edges would work well? Thanks
Old May 4, 2014 | 05:18 PM
mustang125's Avatar
mustang125
I went to a windshield. Now I will never go back except when it is 90 outside.
Old May 4, 2014 | 05:22 PM
Greezey Rider's Avatar
Greezey Rider
Wear a full face...That way you get to have an open casket funeral after the wreck.
But seriously...F/F helmet don't catch nearly as much wind as halfassed helmets do and they actually protect your head better in an accident.
Old May 4, 2014 | 05:31 PM
Blk and Chrome's Avatar
Blk and Chrome
I tighten the strap a little and tilt the helmet forward. I only wear one when I go out of state..
Old May 4, 2014 | 05:34 PM
Kiowa Pilot's Avatar
Kiowa Pilot
Default Licks novdot half helmet
I run a licks novdot mini, after finding right size that had snug fit I find it doesn't lift on me at higher speeds. And if it does for you at all, you probably won't feel as much lift, as it's such a light helmet compared to some of the larger profile half helmets I've ridden with.
I also have a bell 500 3/4 which lifts at higher speeds too, so no luck there for me.
I have found more neck fatigue with full faces helmets as it creates kind of a bobble head effect. With my neck trying to stabilize more weight, fatigue sets in faster.
All of this because I don't have the cash lying around for a windscreen. Hope that was somewhat helpful.
Old May 4, 2014 | 05:48 PM
Mike NY's Avatar
Mike NY
If it has a Visor then there is part of your problem. I stopped using helmets with visors because of that very issue....
Mike
NY
Old May 4, 2014 | 05:56 PM
kneesinthebreeze's Avatar
kneesinthebreeze
http://www.bellhelmets.com/powerspor...treet/pit-boss
This is the helmet I wear and I like it very much. I also have a windshield which I use most of the time but when I am shield less I notice no neck fatigue.
Old May 4, 2014 | 06:45 PM
Msmall's Avatar
Msmall
Interesting, my outlaw helmet with the small visor helps. It creats a bit of downforce at speed. Without visor in have issues, with visor no issues
Mike
NY
Old May 4, 2014 | 07:33 PM
cosshog's Avatar
cosshog
I had the same problem with half helmet and no shield. Went to a Bell 500 3/4 helmet and have been very happy with results.
Old May 4, 2014 | 07:46 PM
jreichart's Avatar
jreichart
You'll probably have that issue with any DOT helmet, even some of the non DOT. I've used a Voss half novelty for years. It used to parachute a bit till I figured out how to adjust the straps. The voss allows you to adjust the 'y' strap around the ears. I shortened the front strap so it sits low on my forehead and no more problems with parachuting.
