Deuce throttle cable routing?
Old May 7, 2014 | 07:32 PM
Spurlee's Avatar
Spurlee
Default Deuce throttle cable routing?
My 2003 Deuce with stock handlebars significantly increases idle speed when the bars are turned fully to the right. It's annoying and potentially dangerous in low speed maneuvers. This bike is now-to-me and I suspect the PO had some work done and the cables were routed incorrectly...
Can someone provide a routing diagram from their shop manual?
Thank you!
Old May 7, 2014 | 08:28 PM
dennyo's Avatar
dennyo
Sounds like just a Throttle Cable Adjustment is needed .
Old May 7, 2014 | 08:31 PM
flibuoy's Avatar
flibuoy
First thing I would do is check the adjustment on the throttle cables....that is so easy and almost intuitive I imagine you already did that.
Old May 8, 2014 | 05:43 AM
Spurlee's Avatar
Spurlee
Default Throttle cable adjustment
Ha! There were two things on my agenda when I posted. 1) Adjust the throttle cable so that it has a bit more free play and, 2) figure out the idle issue. It looks as if the first might resolve the second.
Thanks!
whylee
Dec 12, 2018 09:42 AM
unclerogi
Jun 4, 2012 11:59 PM
champ198
Nov 10, 2010 06:42 PM
Big Hog
Exhaust System Topics
Jan 24, 2010 09:20 PM
labfreak
Jan 7, 2008 11:51 PM
