08 softail screamin eagle baffels
Old May 25, 2014 | 11:44 PM
flstc0888's Avatar
flstc0888
Stage II
Default 08 softail screamin eagle baffels
I am wanting to take out the baffels on an 08 flstc that currently has screamin eagle pipes on it.Does anyone have any suggestions as to if, I will need a tunner and or a mapping sensor.I just upgraded from a fxdwg to this and I just do not know much about this yet thanks in advance for any help
Old May 26, 2014 | 01:45 AM
rbeamj's Avatar
rbeamj
Chances are the person you purchased the bike from did a tune already; however, having said that you really should not remove a baffle and not replace it with a different one. This is in part due to the engine needing a bit of back pressure so as to not lose low end torque.
If you are unsure the status of the efi calibration of your ride, then a safe bet is to buy a tuner or some xeid's. The latter will be cheaper and work pretty good for minor upgrades such as air cleaner and pipes.
Old May 26, 2014 | 10:07 AM
flstc0888's Avatar
flstc0888
Stage II
Thumbs up pipes
I think I will just have V&H Longshots and their tuner installed.I was really unsure if the baffels being out would cause a problem, but I think I would have to agree with you thanks
Wideglide2004
Oct 9, 2017 02:07 PM
Harley Cycle
Mar 13, 2013 03:15 PM
MobyMan30
Feb 12, 2009 10:35 PM
rabidd
Dec 6, 2007 07:37 AM
garcon
Apr 20, 2007 02:25 AM
