Whine in primary?
Old May 27, 2014 | 07:53 PM
Bryan Boyette's Avatar
Bryan Boyette
Stage II
Default Whine in primary?
I am in need of some help or any information at all, I have a 2009 heritage softail, I have a horrific whine coming from my primary, it is rpm related more rpms the louder it gets, and the warmer the motor is the louder the whine, does it in neutral, in gear, moving and not moving does it constantly, has anybody ever had this problem before? I have had the primary cover off and didn't see anything out of the ordinary. Any help would be great.
Old May 28, 2014 | 06:30 AM
Sgt_Jim's Avatar
Sgt_Jim
nope..haven't had that issue, sorry
Old May 28, 2014 | 07:40 AM
haak30's Avatar
haak30
I had the same issue on my train, at 20,000 miles I had a bearing that failed on me.
Old May 28, 2014 | 07:43 AM
Pitbull_Dallas's Avatar
Pitbull_Dallas
I'd get it to the dealer. Sounds like you may have a bearing or stator issue.
Old May 28, 2014 | 07:47 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Try this:
With the engine running, transmission in neutral, clutch lever released.
Noise is present.
Now pull in clutch lever and drop into st gear. Does the noise stop?
Old May 28, 2014 | 08:37 AM
JohnnyC's Avatar
JohnnyC
Sounds to me like your primary chain is over-tightened and howling. Could be a bad adjuster.
Running it like this will severely damage bearings related to the primary, and even the compensator.
Old May 28, 2014 | 09:45 AM
Bryan Boyette
Stage II
I checked the primary chain and it about 5/8 play which is about right, I did order a hayden tensioner to see if maybe that will help, and the noise is present at all times but barely noticeable at high speeds, it's really bad at about 20mph going through town, which bearing did you end up replacing?
Old May 28, 2014 | 04:56 PM
Warp Factor's Avatar
Warp Factor
Originally Posted by Bryan Boyette
I am in need of some help or any information at all, I have a 2009 heritage softail, I have a horrific whine coming from my primary...
Did you pull the cover to see if your ol' lady is trapped in there?
Old May 28, 2014 | 05:19 PM
Echo6 Sierra's Avatar
Echo6 Sierra
I had a whine coming from my primary, but it was only on decel. If I pulled in the clutch, it went away. It turned out to be the inner primary bearing. I addressed it ASAP, so maybe that's why it wasn't constant for me.
fxdx_ftw
Jan 30, 2018 10:18 PM
big- mike
May 28, 2017 09:11 PM
Pondskipper
Oct 1, 2012 10:33 AM
Rowdy25
Sep 1, 2010 08:17 PM
1hot softail
Sep 16, 2007 07:50 PM
