Performance upgrade suggestions please!
Old May 29, 2014 | 10:57 AM
arrowslinger1980's Avatar
arrowslinger1980
Default Performance upgrade suggestions please!
Ok so here we go. 2011 heritage, stock 96" with stage 1 (ac and fishtails). I am absolutely disappointed in the power this bike makes. I know fishtails aren't known for power but hey, I like em. Anyway, it just seems like I have very sluggish acceleration at speed (6th gear, passing cars) It just seems very doggy. My night train with a stock carbed 88" will absolutely walk all over my heritage. I ride 2 up the majority of the time, I take long trips with this bike frequently.
I have been quoted a price on a 107" upgrade with head work, cams, and stuff that seemed reasonable.
What would you guys suggest for my riding style. I absolutely require reliability over hot rod speed. But it just seems that it currently doesn't have enough to make me happy. wait, im never happy hahahha
Old May 29, 2014 | 11:29 AM
WildBill_50's Avatar
WildBill_50
What are you using for fuel management? You may be able to make the motor run better with a new map.
Old May 29, 2014 | 12:14 PM
NDBadlands4-2's Avatar
NDBadlands4-2
Do you still have the stock air cleaner and tuner? If so, I would look into changing them.
Old May 29, 2014 | 12:21 PM
UT-rckr's Avatar
UT-rckr
Downshift to 5th for passing
Old May 29, 2014 | 12:26 PM
jcallesano's Avatar
jcallesano
You can do cams, ported heads, forged high comp pistons and a tune for 100hp - 100TQ
Dont bother with the 107. It will produce a **** ton of heat.
Old May 29, 2014 | 01:12 PM
arrowslinger1980
I currently have a SERT pro and screaming eagle air cleaner.
Old May 29, 2014 | 02:51 PM
tbonetony06's Avatar
tbonetony06
1 fact missing is how much do you want spend? Cam, headwork, SE pro tuner and dyno. I have an 06 that was a stock 88 and is now a big bore with all the compliments of a build. I took the SE heads off this winter to have them flowed, ported and polished and some valve, springs and guides tweaked. I am very anxious to get them on next week then put it on the dyno to see the results. It has all the power I needed and then some for how I ride.
Old May 29, 2014 | 05:40 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
You don't say if you're stock now or already done a Stage 1.
If you're still stock, or have a poorly matched Stage 1, you can pick up some pretty good power with a well done Stage 1.
Below is a chart of my Softail with fishtails. It was pretty doggy, but is making more than enough power now (for me), and well matched Stage 1 was significantly less than a 107 in cost.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old May 29, 2014 | 07:28 PM
TheTroupe's Avatar
TheTroupe
Add a bolt on cam, shot money and best bang for the buck.
I like the SE-204 for great low rpm power, but for highway set up there are other options as well.
Old May 29, 2014 | 08:12 PM
dimefan's Avatar
dimefan
Funny....I didn't even know I had a 6th gear ( was completely useless ) until I did stage 1 and a Power Vision. Now, I can actually use 6th gear without going 80mph!
