Vied install
Old May 29, 2014 | 04:18 PM
rbeamj's Avatar
rbeamj
Default Vied install
Can anyone recommend where to ground the vied in the front of a 14 heritage. Wire that came with the vied isn't long enough to get to the battery
Old May 29, 2014 | 05:39 PM
ddrumman2004's Avatar
ddrumman2004
Only dumb question is the one that's not asked.....so I'll ask it.....
What is a "vied"?
Old May 29, 2014 | 05:42 PM
roadglider05's Avatar
roadglider05
Use a couple of butt connectors and a piece of wire to get it to the battery.
Old May 29, 2014 | 06:01 PM
mmcbeat's Avatar
mmcbeat
Yeah, I would just extend the lead. I had one on my Deluxe for a while and the lead was plenty long.
edit: I just noticed you said front. I grounded mine to the bolt that holds the voltage regulator to the frame.
Old May 29, 2014 | 06:17 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
You can ground it on any frame bolt.
What is a "vied"?
Here is a LINK with explanation.
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old May 29, 2014 | 06:32 PM
rbeamj's Avatar
rbeamj
Ty DK. I placed it on the rear brake mounting bracket bolt.
Old May 29, 2014 | 06:44 PM
jam436's Avatar
jam436
On my Slim the connector for the front O2 sensor was behind the regulator, so I just ran that ground to the regulator mount bolt...
Old May 29, 2014 | 06:54 PM
300Slim's Avatar
300Slim
Jam, V or X. Is it all that you expect it you be?? thanx.
Old May 29, 2014 | 07:21 PM
TheTroupe's Avatar
TheTroupe
What is a "vied"?
A waste of money. Just my opinion.
Old May 29, 2014 | 08:21 PM
jam436's Avatar
jam436
After a less than spectacular dealer "remap", my oil temps soared, decel pop was unbearable and my average MPG also climbed.
The ViED's cured all three problems, but I've since moved on to a V&H Fuelpak3.
In the end though, I was glad I chose the ViED's (variable) over the XiED's, which are not adjustable and essentially run wide open.
The ability to tweak the settings really paid off.
Here's my original ViED review from a year ago...
https://www.hdforums.com/forum/softa...than-ever.html
