Vied install
Old May 29, 2014 | 09:26 PM
rbeamj's Avatar
rbeamj
I purchased the vied after using a SE street tuner and install of my V&H pipes. I also had a bad pop when changing gears and upon decel.
After installation the pop when shifting is gone but still light popping in decel.
Most tuners cost 3-400 dollars and can cause issues with HD for warranty claims. With the vied I can remove them in 5-10 minutes and not have to stress over at the dealership should anything warranty related arise.
So far the bike rides smoother after installing the VIED and I have about 250 invested including my SE tuner and a used pair of VIED's
Old May 30, 2014 | 11:08 AM
rideflhr's Avatar
rideflhr
Originally Posted by jam436
On my Slim the connector for the front O2 sensor was behind the regulator, so I just ran that ground to the regulator mount bolt...
Me too.
Old May 30, 2014 | 01:30 PM
rbeamj's Avatar
rbeamj
Thought about grounding to the regulator. Problem was I have ABS and the bracket that holds the regulator is attached to the ABS module. The ABS module is attached via plastic brackets to the frame and not grounded
whocares
Audio Systems
Apr 16, 2018 09:48 PM
BFJR
Jul 16, 2013 12:13 PM
PowerDude
Sep 4, 2012 10:59 PM
Randall
Jun 9, 2011 12:17 PM
HDF Tech
Electrical/Lighting/Alarm
Aug 20, 2005 05:36 PM
