Ground wire question.
Old Apr 16, 2018 | 05:39 PM
whocares's Avatar
whocares
Default Ground wire question.
I know very little about adding an amp to my bike.my question is,does the ground wire for the amp have to be attached to the battery or can I ground it to the frame? The reason I'm asking this is because the ground wire in most kits are only 3 ft in lenght.any help is appreciated.
Old Apr 16, 2018 | 05:44 PM
MURPHCC1's Avatar
MURPHCC1
Any good ground to the frame will suffice.
I got mine grounded to a bolt on the right side near the gooseneck........WORKS FINE!
I got too many things attached to the battery now........gotta use a longer screw to get all those things attached..........
I'll fix it sooner or later..........
Old Apr 16, 2018 | 05:49 PM
azlou66's Avatar
azlou66
Ground it to the battery.......... You can order wire, terminals, etc from Amazon, Crutchfield, Sonic Electronics and so on.
Old Apr 16, 2018 | 06:49 PM
Tailwind's Avatar
Tailwind
The only place on the frame I would Ground to would be the ground post about 6" forward of the battery.
T
Old Apr 16, 2018 | 07:57 PM
whocares's Avatar
whocares
Thanks for the responses guys!
Old Apr 16, 2018 | 08:05 PM
Kitsoldman's Avatar
Kitsoldman
T
That’s where I put mine, a good chassis star ground will keep you from having loop or intermittent troubles.
Old Apr 16, 2018 | 09:48 PM
azlou66's Avatar
azlou66
T
Yes Sir.
Biggzed
Audio Systems
13
Feb 20, 2018 07:24 AM
ORradtech
Electrical/Lighting/Alarm
Apr 19, 2016 07:15 AM
PowerDude
Sep 4, 2012 10:59 PM
SgtMic
Jun 29, 2009 12:12 PM
HSMaxim
Flathead
Mar 22, 2008 09:06 PM
