Regulator Vandalism
Old Jul 10, 2013 | 01:25 PM
BFJR's Avatar
BFJR
Default Regulator Vandalism
Had someone/s cut me Voltage regulator connection (Deutsch Connecter 2 pin) from the battery side.
Thought that if I just make a straight connection with butt connectors it would be allright.
No so, when I did this it blew the Main Fuse straight away!
When I disconnect the two wires it still blows fuse (wires stripped but not touching anything).
When I cut regulator wire from battery side clean without wires showing, the fuse does not blow!
What am I missing?
Oh, I'll handle the vandals after my rides right again.
Thank you
Old Jul 10, 2013 | 02:35 PM
88vicla's Avatar
88vicla
Sounds like your ground is crap, disconnect it and clean the surface if that blows the fuse try soldering the wires with lead free solder.
Old Jul 10, 2013 | 03:14 PM
BFJR's Avatar
BFJR
That makes sense and I'm not adverse to cleaning and tighten again.
both reg. and battery ground, right?
Old Jul 10, 2013 | 06:40 PM
Michael knowles's Avatar
Michael knowles
I'm confused with description. Disconnect positive on battery. Check with ohm meter for short to ground. A fuse usually blows when there's a dead short.
Old Jul 16, 2013 | 09:26 AM
BFJR's Avatar
BFJR
Wanted to not leave this open ended.
1st Thanks to the Forum and it's members for all the tips in regards to this issue as well as other items gleaned from you all.
Also a shout out to the "Garage Co." her in L.A.
Marty is a Good Wrench and got me back on the road in no time!
If your in L.A. and you want to see some killer Rides, stop by and check them out.
This place is as much a Museum as it is a working Shop!
Turns out Stator shorted to Ground.
If I had taken her to Shop 1st off would of saved $140!
I do my own wrenching, but electrical................. well
It's all Good Now, Thanks.
Old Jul 16, 2013 | 11:08 AM
jam436's Avatar
jam436
I'm still waiting to hear this part of the story...
Old Jul 16, 2013 | 11:48 AM
BFJR's Avatar
BFJR
I should of known that was coming
I was Hmmm .... pissed when I typed that, should of kept it to myself and will.
Sorry.
Old Jul 16, 2013 | 12:13 PM
jam436's Avatar
jam436
Sorry.
heh, no problem... I know the feeling...
hdbeggs
May 29, 2013 06:36 PM
Randall
Jun 9, 2011 12:17 PM
skruzluce
Sep 21, 2009 07:11 PM
lagunatic
Ironhead
Aug 29, 2009 05:51 PM
chazreid
Ironhead
Jul 7, 2006 01:52 AM
