HELP: Ness Control Extension Install
Old Mar 31, 2007 | 02:23 PM
blackbirdxx's Avatar
blackbirdxx
Default HELP: Ness Control Extension Install
I'm in the middle of installing the Ness 3" FC extensions on my 07 Deluxe. I'm just down to the rear brake line. The line that was included in the Ness kit comes with a block installed in the middle of it but when I trace the OEM line, I don't see anything else that will mount to it. Is this block included for other models? Where am I going wrong?
Thanks in advance to anyone who can help...I know many have installed this kit.
Old Mar 31, 2007 | 03:49 PM
agapsdiver's Avatar
agapsdiver
Default RE: HELP: Ness Control Extension Install
On my '03, the "block" is where the sensor for the brake light is located. It was a straight forward replacement for my '03 NT.
Old Mar 31, 2007 | 04:46 PM
Unibomber's Avatar
Unibomber
Yeah its the rear brake light pressure sensor, not sure if the '07 setup is the same, trace every inch of your line and see if it comes to the little box. My '05 springer was pretty cut and dry.
Old Mar 31, 2007 | 05:31 PM
blackbirdxx
Yea that was it...I put the new brake line on backwards at first and it wasn't aligned...worked perfect once I took a second look.
Thanks for the help!
Ragnar
Aug 17, 2013 11:29 AM
06 fxstbi
Oct 26, 2010 11:01 PM
brrobin
Sep 23, 2008 08:45 AM
mt325
Mar 11, 2008 06:45 AM
bluesammyny1
Jul 27, 2007 05:37 PM
