Vibration. Normal or not?
Old Jun 2, 2014 | 06:33 PM
martin1's Avatar
martin1
Default Vibration. Normal or not?
My new Softail Slim has almost no vibration until you get to about 3200 rpms. 3200 rpms and above there is some vibration that gets a little worse as the rpms increase. Since I am new to the balanced engines I thought I would ask if this is normal. Thanks.
Old Jun 2, 2014 | 06:40 PM
Sgt_Jim's Avatar
Sgt_Jim
quite normal. you could add weights to the end of your handlebars to try to dampen it a bit if it's too much for you
Phrogman's Avatar
Phrogman
Yes, some vibes are normal at higher RPMs. The dampers can't overcome everything and slinging those big pistons around at higher RPMs is gonna cause some shaking. They engineered the system to keep the bike smooth at cruising RPMs, so between 2000-3000.
Old Jun 3, 2014 | 02:29 AM
4_stroke's Avatar
4_stroke
Its not completely balanced, it only balances the primary out of balance forces not the secondary forces, these get worse at high engine RPM.
Old Jun 3, 2014 | 06:36 AM
martin1's Avatar
martin1
Thanks for the responses. That is what I figured it would be.
dwoodlives
Jul 26, 2018 12:48 PM
mrfikser
Nov 18, 2017 05:42 PM
thessler3
Nov 6, 2017 06:21 AM
TurboGliding
Sep 13, 2017 06:43 PM
cathxiii
May 20, 2017 12:12 AM
