Heel & Toe Lever Heights .
Old Jun 14, 2014 | 08:22 AM
want2ride's Avatar
want2ride
Originally Posted by funbikerchick
Mine is set at stock as was the one on my Suzuki C50 (my Street Bob didn't have one and I really missed it). However, after reading this, I might lower the back one a bit so I don't have to lift my foot as high to shift it. I really find the downward action much more comfortable than the upward motion. I have never been able to just lift my toe. For whatever reason I have always had to actually lift my foot. So, while I love my heel-toe shifter, this thread has shown me how to make it even better. Yeah, I get its not rocket science, but then again, I am not a rocket scientist... lol
I highly agree (funbikerchick) Im no where near a rocket scientist. I was hoping to learn a few things here on the forum regarding everyones heel & toe lever positions for exactly that, Fresh idea's.
Old Jun 14, 2014 | 08:30 AM
jeffreydsilver's Avatar
jeffreydsilver
Originally Posted by dansax
It's not rocket science. Set it up to where you feel comfortable.
The FIRST thing you should do with ANY bike you are riding would be to set up ALL the controls to where they are most comfortable for you. This would include handle bars, hand controls and , foot controls. In particular, with the shift levers, I installed the longer HD billet levers. WAY more room for my foot. BTW - You'll find out that properly adjusted shift levers will make it SO much easier to find neutral!
I don't understand why dealers don't "set up" a new bike for their customers.
Old Jun 14, 2014 | 09:28 AM
Dutch101st's Avatar
Dutch101st
Hmmmm...I haven't really given much thought to adjusting my levers...I do not use the heel shifter at all because, well I learned with just the toe. I always did feel the heel was too high. Maybe some experimentation with the heel adjustment is in order
Old Jun 14, 2014 | 04:37 PM
hdbob2006's Avatar
hdbob2006
I moved mine up a little,found out it's a lot easier to find neutral from first.[I can use some of my foot,rather than just my toe,to shift to neutral-more leverage]
Old Jun 14, 2014 | 04:43 PM
TenMidgets's Avatar
TenMidgets
If you get an extension for the rear you can actually place it behind and slightly below the floor board. Still can shift easily with any boot heel and there is no rear limit to where you place your foot.
Old Jun 15, 2014 | 01:10 AM
WildBill2566's Avatar
WildBill2566
Originally Posted by want2ride
Another new member/owner question here, I noticed in your pictures that "most" of you heel & toe shifter equipped bike owners have your Levers set on the high side more so the toe lever. Was that a trial and error type setting for most of you riders, any special advantages to having them (it) set higher ? especially the toe lever, I see most photos that the toe lever is set up higher then heel lever. I know the boot needs to clear it, but in some pix it looks like its much higher then most bikes I seen on showroom floors. Thanks all.
On bikes I use heel n toe levers on I always change them for longer items so they extend beyond the floorboards a little. I then set them so they are as low as they can be and still function, this is usually so that the top of the shifter only sits an inch or so above the board. When I change gear don't really have to raise my foot much at all, simply slide forward and press down or same with heel.
Old Jun 17, 2014 | 06:07 PM
flipbel's Avatar
flipbel
Originally Posted by misbehaven
i have mine setup with the front high enough so i can still get my boot under it if i want to toe shift up. The heel shiftier is set to it lowest point so i dont have to raise my heel way up to shift. Alot of times while going up the gears i just mash down on the heel shiftier to shift up then just barley lift my heel to set up for the next gear change, all the time my heel is always making contact with the lever.
++++1111111
Old Jun 17, 2014 | 07:04 PM
Goldtop Dude's Avatar
Goldtop Dude
Good thread, I will try some new settings and maybe some extended options.
Old Jun 17, 2014 | 07:06 PM
VB2KDH's Avatar
VB2KDH
Originally Posted by TenMidgets
I just ordered an extended rear shifter to lower the peg just off and slightly under the rear of the floorboard so I can have use of the rear shifter and move my feet back on the floorboard. Going to lower the front shifter as I only use it to downshift.
exactly what i have recently done.
Old Jun 18, 2014 | 05:47 AM
Goldtop Dude
Originally Posted by jeffreydsilver
The FIRST thing you should do with ANY bike you are riding would be to set up ALL the controls to where they are most comfortable for you. This would include handle bars, hand controls and , foot controls. In particular, with the shift levers, I installed the longer HD billet levers. WAY more room for my foot. BTW - You'll find out that properly adjusted shift levers will make it SO much easier to find neutral! I don't understand why dealers don't "set up" a new bike for their customers.
Completely agree! I'd pay an extra 50 bucks when buying a bike........... insignificant considering the total cost of the motorcycle.........
