SEPST Map Request. '13 Softail 103
Old Jul 16, 2014 | 09:50 AM
BigMike's Avatar
BigMike
Default SEPST Map Request. '13 Softail 103
Does anyone have a SEPST map that has been tuned for a '13 103 or similar?
I have V&H Shortshots with the SE Heavy Breather. The Stage 1 map sucks with tons of decel popping.
I plan to use Smart Tune to dial it in but if someone has one that has already been done, it would certainly help.
Thanks.
Old Jul 16, 2014 | 11:50 AM
gchristopher9's Avatar
gchristopher9
Good luck to you bro. I looked for some similar info a while back and got absolutely no help. And for me, smart tuning did not get rid of decel pop at all.
Old Jul 17, 2014 | 08:02 PM
asa1199's Avatar
asa1199
Try these in your A/F Ratio
Old Jul 17, 2014 | 09:03 PM
rbeamj's Avatar
rbeamj
The street tuner can only adjust VE tables. Try richening the 0 and 2.3 percent throttle tables 2 points richer. This may help the decel popping
Old Jul 17, 2014 | 09:32 PM
harty's Avatar
harty
I can send you a map tonight when I get home. I have 2014 103" softail breakout. I had alot of decel pop and was given a good base afr table(from trusted forum member) to start with before I started smart tuning. It did reduce the decel pop and also the bike runs cooler at idle. I will pm you when I get home.
Old Jul 18, 2014 | 02:10 AM
harty's Avatar
harty
Thanks.
I have sent you a PM BigMike
Old Jul 18, 2014 | 08:21 AM
BigMike's Avatar
BigMike
Thanks Harty!!! I responded to your PM
Old Jul 18, 2014 | 09:17 AM
gchristopher9
Harty is the man! Thanks for your help bro! Can't wait to go for a spin and see how things go.
Old Jul 18, 2014 | 11:53 AM
Nostradamus74's Avatar
Nostradamus74
Bigmike I sent you via email my map too.
Old Jul 18, 2014 | 12:12 PM
BigMike's Avatar
BigMike
Got it, thank you very much!!!!
If I get a break between bedlining the inside of my Jeep and the rain this weekend, I'm going to check both maps out and do some Smart Tuning.
You guys rock!
