stage 1 cost for efi
Old Jan 14, 2005 | 01:36 AM
02fatboy66's Avatar
02fatboy66
6th Gear
Default stage 1 cost for efi
I have a efi fatboy with slip on mufflers.Pipes are ok but what should a fellow pay for a
improved backing plate for air cleaner and k&n filter.A improved chip and remap will also be added.dealer says allow about 300
is the dealer trying to take advantage or does this sound about right.
Bill
Old Jan 14, 2005 | 02:35 AM
billnourse's Avatar
billnourse
Default RE: stage 1 cost for efi
Bill,
This is right out of the Harley 2005 Catalog:
Screaming Eagle Air Cleaner kit 139.95
Required ECM Calibration 149.95
Total 289.90
This does not include labor, so 300.00 sounds like a good price.
Regards,
Bill
Old Jan 14, 2005 | 10:29 AM
02fatboy66's Avatar
02fatboy66
6th Gear
Does anybody have a link to the air cleaner kit or the chip and remapping.
Any info helpful before I drop 300 bucks .
I think i could probably install the air cleaner kit but would it run correctly till I decided to take it to the dealer.I figure it probably won't but worth asking instead of dropping 300 bucks at once.
Thanks for any advice.
Bill
Old Jan 14, 2005 | 12:07 PM
pilot1996's Avatar
pilot1996
Bill,
It's going to get you to the dealer. Some decide never to do the map as they think it a waste. The bike will more than likely backfire, and it won't run as it should...meaning you won't have it tuned to give you the best performance.
But, if you're wanting to save a few bones in labor costs...this way should work for ya...
Mac
Old Jan 16, 2005 | 12:33 AM
phoenix's Avatar
phoenix
05 Deluxe- cored the pipes and put a stage 1 kit with remapping- dyno runs before and after yielded 8 HP and a big difference in performance---$350 well spent
Old Jan 16, 2005 | 12:40 AM
02fatboy66's Avatar
02fatboy66
6th Gear
Thanks for the replies I guess 300.00 is a pretty fair deal.
Old Jan 16, 2005 | 01:37 AM
SPRINGER's Avatar
SPRINGER
Since the topic of efi has come up, I've got a question. I'm not familiar with efi on a motorcycle and I was wondering about something. I have been reading American Iron and it talks about the differences between efi and carb. If a person has to make adjustments on the efi when some custom parts are done on the motor, is it really worth the effort as compared to going to a bike with a carb?
Old Jan 16, 2005 | 03:30 AM
Tn.Heritage's Avatar
Tn.Heritage
Farboy, I had mine done a couple of week's ago and it was 304 dollars. As for your question Springer, I have efi on my bike and love it,no warming up long,no sputtering but it cost a little more to adjust than a carb.
Old Jan 17, 2005 | 12:10 PM
billnourse's Avatar
billnourse
Bill,
You can probably install the SE air cleaner yourself. I've done several of them, and it's not rocket science. What you will end up with if you don't remap, is a lean running bike. This means it will run hotter than usual, will probably blue your pipes, and decrease spark plug and oil life.
New Harleys, because of emmissions restrictions, come from the factory very lean, and if you add more air(SE air cleaner, and pipes) without more fuel it just gets leaner. In my opinion it really wouldn't be a good idea to run very long without the remap, but you could certainly run it long enough to get to the dealer for the remap.
Good luck,
Regards,
Bill
98acrsilver
Dyna Parts
Jan 25, 2016 03:32 PM
balloo
Apr 1, 2014 02:54 PM
gejohn
Dec 27, 2013 08:09 AM
MorrisGray
Oct 5, 2013 03:39 PM
Shawnpalmer
May 16, 2012 10:23 AM
