which Air Filter?
Old Jun 29, 2016 | 12:12 PM
LowRider289's Avatar
LowRider289
Originally Posted by oct1949
Over the yrs of researching and learing, Here are some numbers I've found and keep..
Info the CFM's of different Air filter and how much there Air Flow is
HD stock - 171CFM
Stage 1 Big Sucker - 200CFM
Stage 2 Big Sucker - 250CFM
Kuryakyn Twin Velocity - 270CFM
E-3014 = 248 CFM RK-3009 kit
E-3037 = 301 CFM RK-3910 kit
HD-0800 = 231 CFM SE replacement
Doherty Powerpacc - 287CFM
SE Air Cleaner - 287 CFM
Zippers - 321 CFM
Woods Carbs - 4 models 235CFM upto 340CFM
BC Overflow - 800+CFM
Your actual need is (103 X 5800 X .9 divided by 3456 = about 155 CFM) is what your engine will flow and need..
So if you keep you filter clean,,, anything over 250 CFM will/ should be plenty on stock heads and cams 103..
I went with SE/AC and it works well with my cams and no head work, i did buy a Real K&N filter for it,, Not the HD filter made by K&N,, they are not the same
Thinking just get the one that rings your bell and then make sure it has enough flow..
How accurate are these numbers? I am considering a Big sucker or a HD stage 1. Alot of old posts have said the filter is comparable to a K&N. Why does the number show it with lower CFM of 200 vs 231 for K&N HD 0800?
rlfxdwg11
Apr 28, 2012 03:48 PM
justmealwatts
Exhaust System Topics
Aug 9, 2010 12:24 PM
ces2119
May 9, 2010 10:09 PM
mjaw
Nov 10, 2009 02:52 PM
dobeman21
Dec 14, 2008 03:39 PM
