Help!!!!!
Old Aug 3, 2014 | 12:07 PM
tcemery's Avatar
tcemery
3rd Gear
Default Help!!!!!
I hope this isn't a repeat post but I need help! I have an 04 heritage efi and it is running horrible all of a sudden. It coughs and chugs and misses really bad so far that it's seeming to run on 1 cylinder. I have replaced plugs and wires on it. I ran some injection/system cleaner through it and didn't so I sucked all the gas out of the system and put new in and didn't get any better so if anyone can help I would really appreciate it!!!!!!
Old Aug 3, 2014 | 12:40 PM
Misbehaven's Avatar
Misbehaven
How is it at an Idle? Is it running fine? Could be as simple as a clogged fuel filter.
Old Aug 3, 2014 | 05:22 PM
Ramboamt's Avatar
Ramboamt
Are you showing any codes?
Check the connections on the ECM and the BCM.
Old Aug 3, 2014 | 05:24 PM
Stiggy's Avatar
Stiggy
Crankshaft sensor?
Old Aug 5, 2014 | 08:31 PM
tcemery's Avatar
tcemery
3rd Gear
The idle rolls up and down and caughs out of the air cleaner I'm surprised there are no codes in the system the fuel filter is only about a hear old.
Old Aug 5, 2014 | 09:01 PM
Redbeard719's Avatar
Redbeard719
Mileage? You could have pinholes in your internal fuel lines. Does it happen when the tank is full? Or only when less than half?
Old Aug 6, 2014 | 10:02 AM
tcemery's Avatar
tcemery
3rd Gear
just turned 20k it initially started when the tank was under half but now it does it constantly
Doobie60
Oct 18, 2017 11:11 AM
Vrodjoe
Sep 19, 2016 07:39 PM
stan928
Jun 4, 2013 04:29 PM
smbwn
Apr 28, 2013 08:06 PM
satocita
Jun 15, 2009 11:18 PM
